Front-End Loader Loader for 3930
/ Loader for 3930 #1
tbutcher
I recently purchased a New Holland 3930 2 wheel drive tractor. I have been able to determine that New Holland or Ford 7310 loader will fit this machine. Does anyone know of other loaders by Ford/NH or any other manufacturers that will fit the 3930? Model numbers would be very helpful. Thanks. Tim
/ Loader for 3930 #2
Westendorf makes all sorts of loaders. Their TA-160,25 ,26 or 26+ will fit your 2wd NH
/ Loader for 3930 #3
I have a woods 1020 on mine it works great
/ Loader for 3930 #4
Buhler/Allied mounting list shows their model 395 loader for the 3930, under the Ford listings. Bush Hog and Rhino probably also have mounting kits for the 3930, you would neede to talk to one of their dealers, as I couldn't find anything specific on their websites.
/ Loader for 3930 #5
I have an Allied loader on mine. Works good
/ Loader for 3930 #6
I am in the same boat, 3930 2 wheel drive. I have been told the 7309 fits not the 7310 I have seen pictures of the 3930 with a 7309 loader Good Luck
/ Loader for 3930 #7
My 99 3930 wears a Quicke 310 from that same year. With a 2wd make sure of your counterbalance. I use a 1000# boxblade. You will have problems with heavy stuff like sand and gravel without some real good rear end weight.
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
10in Digging Tooth Bucket Excavator Attachment (A64194)
10in Digging Tooth...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
