Loader Feedline - swap to other side
/ Loader Feedline - swap to other side #1
BeachEx
Sanford, nc
1997 John Deere 1070
I recently bought a John Deere 1070 with a Du-al 165 loader. The hard feedlines run down the right side of the loader, the soft lines run under the tractor and I'm worried about snatching them when bushogging.
I want to run the hard feedlines on the left side of the loader so the softlines will only need to be about 3 feet long and run directly to the hard feedlines.
If I order feed lines for a John Deere loader that run down the left side will that work?
/ Loader Feedline - swap to other side #2
Can you reroute the hoses up higher?
Which side is the loader valve on?
Add metal guard over the hoses, so they can't get snagged.
/ Loader Feedline - swap to other side #3
If you don't find any other way you like take it to a Parker hydraulics store. They will use what they can of your parts and then finish it professionally.
Add metal guard over the hoses, so they can't get snagged.[/
the only way I could re-route the lines higher is up and over the hood of the tractor, not ideal.
I could pull the lines under the tractor up a little but not much.
The quick connects for the loader are on the left side of the tractor, I have a friend with the same tractor but he has a JD loader. His hard feedlines run up the left side of the loader and have short soft lines about 3' connecting.
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
(APPROX. 29) ASSORTED ROUGH SAWN PINE (A64276)
(APPROX. 29)...
Frontier BB5048L (A64126)
Frontier BB5048L...
2006 Kawasaki Bayou 250 (A64127)
2006 Kawasaki...
