loader cylinder seals
/ loader cylinder seals #1
Oldawg
Fort Myers, FL
IH 300U, Ford 4500 FEL/BH, Farmall Cubs (2), Kubota L3130 with FEL, Craftsman & Scott lawn tractors
Need to reseal front loader cylinder on L3130. Anything unusual here? Can I leave hoses connected?
/ loader cylinder seals #2
Seal replacement is a job which looks easy but done improperly and a leaking seal soon afterwards is likely.
Unfortunately, to do a seal replacement properly Kubota recommends two special tools which they do not sell.
See page two of the attached which is for a different loader than yours but the procedure is the same.
A SLIDE jig to stretch the seal to get it over the piston and then a CORRECTING jig to compress the seal.
Messicks has provided instructions of a sort as they also do not have the tool.
Lastly, a special tool to install the seal inside the gland nut.
Dave M7040
  • Loader seal replacement.pdf
  • Forum LA seals.pdf
  • Rod seal installation tools.pdf
/ loader cylinder seals #3
I've never done any other cylinders other than those which are on my machine so my experience is limited.
For years, I would pull an offending cylinder pair off, take them to the shop, pay to have it done.
Finally, knowing I'm mechanically inclined....I thought what do I have to lose to try one myself??!! So I did.
I very much regret having taken the others to the shop to do what I could have done faster and less expensive.
I don't know what their names are but one of the tools I have is sort of like an ice pick but, instead of going to a point at the end (I have that one too) I have a set of them.....one is straight (like the ice pick) one has a 45 degree bend at the tip, one has a 90 degree another has a hook at the end. I've found these to come in handy.
When I put the piston seal on, I put painters tape over the threads and just took my time. By the time I got to my third cylinder, I realized I can go ahead and put some PULL on it to stretch it over the end of my piston.
If you're mechanically inclined, resourceful have a general set of tools (one thing you might need is that spanner tool in the above PDF.... I have one of those, but didn't need it. I can use a wrench (pipe) on mine. I have the spanner item to do the height cylinders on my 15' mower but so far, have decided the cut height is fine so just unhooked the cylinders so they don't leak.
You need to be in your comfort zone, but I'm of the camp that says what do you have to lose? If you get it off, get it apart.... can't get it back together, you can then have it done for you.
And no, you can't leave hoses connected unless you're able to do rebuild while on machine (or at least the initial loosen/re-tighten of the end cap) Looking at my industrial, I could do all of them while on the machine, would need to unhook ram end, withdraw rod....then have at it. Still, you're going to have suction in there so you'd have to loosen the hoses.
Oh, and have a bucket ready. You're going to have some amount of fluid drain out whether or not you do them yourself or take them off to have done..... that residual fluid in the cylinder gets me every time!!
Oh, and I've now discovered I could have left my backhoe trunion cylinders in place to redo them instead of the herculean gymnastics I went through to remove them and worse.....remount them.
Live & learn. Once I realized that.... AND saw the pins holding my stabilizers onto machine were frozen in place, I decided NOT to fight the pins and simply rebuilt the stabilizers while they were on the machine.
Give it a whirl!!!
John Deere HX15 (A64126)
John Deere HX15...
1981 Chevrolet Corvette (A62613)
1981 Chevrolet...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
Frontier Root Grapple (A64126)
Frontier Root...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
159118 (A60430)
159118 (A60430)
