Front-End Loader Loader cylinder repair
/ Loader cylinder repair #1
harpman
Zavalla,TX
Kabota 2500 DT
Anyone know a source besides Snap-on for a spanner wrench to fit a Kabota LB 400 loader hyd cylinder? The nut is 2.14" (54mm) and has a 5/32" (3.8mm)hole.
/ Loader cylinder repair #2
Mac tools, Mcmaster Carr, W.W. Grainger, NAPA, to name a few.
/ Loader cylinder repair #3
Anyone know a source besides Snap-on for a spanner wrench...
Unless you are in the biz, you don't really have to buy a special tool at all. What I do
for that style of cylinder is I take some salvaged rollers from old tapered roller bearings,
then tap them in the gland hole. Then I wrap the gland with a rag to avoid scratching it.
Finally, I take some giant Channel-lock pliers and grab/turn. The tapered rollers wedge
in pretty well, and are easy to remove.
If the gland is already scratched up, then I just use a big pipe wrench.
/ Loader cylinder repair #5
baileynet.com also carries spanner wrenches for cylinders.
/ Loader cylinder repair #6
I bought mine from amazon. Do a search for "adjustable pin spanner"
Thanks to all you for your help.
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
iDrive TDS-2010H...
150 GALLON FUEL TANKS (A65643)
150 GALLON FUEL...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
