Front-End Loader Loader cylinder repair
   / Loader cylinder repair #1
harpman
Zavalla,TX
Kabota 2500 DT
Anyone know a source besides Snap-on for a spanner wrench to fit a Kabota LB 400 loader hyd cylinder? The nut is 2.14" (54mm) and has a 5/32" (3.8mm)hole.
   / Loader cylinder repair #2
Mac tools, Mcmaster Carr, W.W. Grainger, NAPA, to name a few.
   / Loader cylinder repair #3
Anyone know a source besides Snap-on for a spanner wrench...
Unless you are in the biz, you don't really have to buy a special tool at all. What I do
for that style of cylinder is I take some salvaged rollers from old tapered roller bearings,
then tap them in the gland hole. Then I wrap the gland with a rag to avoid scratching it.
Finally, I take some giant Channel-lock pliers and grab/turn. The tapered rollers wedge
in pretty well, and are easy to remove.
If the gland is already scratched up, then I just use a big pipe wrench.
   / Loader cylinder repair #5
baileynet.com also carries spanner wrenches for cylinders.
   / Loader cylinder repair #6
I bought mine from amazon. Do a search for "adjustable pin spanner"
Thanks to all you for your help.
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2013 Isuzu NPR-HD 16FT Reefer Box Truck (A50323)
2013 Isuzu NPR-HD...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2015 Peterbilt 320 EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
KJ 10' Galvalume Corrugated Steel Panals (A50121)
KJ 10' Galvalume...
