Loader control valve
/ Loader control valve #1
Beluga225
1980 Kubota B7100D-P
I’m in the process of replacing the hydraulic control valve on my B219 loader mounted on my 1980 Kubota B7100D. The stock valve #70050 00052 has been upgraded to #70050 00191, which I just purchased NOS.
The mounting is fine but the in- out hydraulic hoses mount to the front of the new valve vs sides of original. Looks like the “in” hose will work, but the “out” hose fitting is for a 1/2” hose vs the 3/4” stock. Before I get started, I was wondering if anyone is familiar with this upgrade? Any feedback would be greatly appreciated. Thank you!!
/ Loader control valve #2
Needing adapters & fittings seem to be a part of every one of my hydraulic projects.
I use surpluscenter.com - mainly because they are helpful on the phone.
If you can identify the fittings yourself just Google "Hydraulic Fittings and Adapters"
to find lots of sources inexpensively.
BTW, even if the threads match, its best to use hydraulic pressure rated adapters rather than household plumbing parts from the hardware store. .
rScotty,
BIG help,Thank you very much!!
I’ll give them a try.
/ Loader control valve #5
Have you looked to confirm that there is not a second in and out port on the new valve? Reason for asking is some valves have multiple options and you can use which ever port works the best for your application. Just plug the unused ports.
/ Loader control valve #6
In a similar vein has any one found a loader valve they are really happy with?
And if so what was the brand?
I'm about to replace one for a second time, the original is a cable operated large heavy cast unit made in Turkey,
I have replaced it once already and both of them have been rough on the cables and the float detents have been difficult to get into and out from. They have required constant cable adjustment and repair as well as cleaning and lubing of the detent.
I am seriously considering an electrical proportion controlled unit.
/ Loader control valve #7
Lou
What flow rate do you need for that valve.
Best valves I have operated were on Kubota and John Deere CUT tractors but I don’t know who makes valves for either of those companies nor if those companies make valves to be purchased as a separate item.
PTSG has mentioned Badestnost brand valves but I have never used one to my knowledge.
Prince has discontinued building their line of LV* loader valves. I have a LVT and it is OK but not exceptional.
Brand hydraulics shows having a loader valve but again no actual hands on use.
If going proportional the Danfoss PVG is well known and respected valve line.
Good luck in your search.
Oldnslo, thank you for your feedback. There are only the two ports to work with. The new casting covers up where the old ports were. Thanks again.
2019 International LT625 Sleeper 48" (A62613)
2019 International...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
(2) UNUSED 420/85R34 TIRES ONLY (A64280)
(2) UNUSED...
