loader control valve question
/ loader control valve question #1
BISONBUSTER
MD
satoh bison s650g
I have a Satoh s650g with an after market front end loader(Black Hawk). The control valves(AICO) are very worn and leak like crazy. Can I replace the valve controls with any 2 spool 4way controls? I've been having trouble trying to locate one small enough. Everyone I found looks like it's made for a large piece of equipment. Can anyone recommend a good replacement system that will work?
/ loader control valve question #3
That one from the SurplusCenter is a perfect fit. Where in MD are you?
Thanks for the info. I went on that site and found another one that looks just like the one I have now...would fit perfect. It's only 5gpm though(not sure what the original is), does that matter much? I added a link to the part.
Surplus Center Item Detail
/ loader control valve question #5
That Cessna compact valve is great for small CUT's. The 5gpm rating is also probably enough for your tractor. You must NOT put a valve in your system that has a rating that's less than your tractor's though or you can damage your pump or overheat the hydraulic oil.
We suggested the joystick valve because it's a lot easier to operate the FEL with one-but if you have a two stick setup now and want to keep it then that is your decision. Also-that valve does not not have a float detent, something that's very handy for a FEL.
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
2014 KOMATSU PC138US-2E0 EXCAVATOR (A65053)
2014 KOMATSU...
HD Bale Ring (A66408)
Sand Blast Pot (A65579)
Sand Blast Pot...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59914)
2019 CHEVROLET...
