Loader control like on a JD?
/ Loader control like on a JD? #1
dieselsmith
NW PA
Kubota L 2800 HST
I noticed the new L-39 TLB and a few other Kubotas have the loader joystick by your right leg now instead of way up high on the loader mount. I would like to conver the one on my L2800 like this. Coming from a JD to a Kubota, I have found this to be most uncomfortable from the transition. I am sure it has been converted before, I wonder if there is a kit? Let me know what you guys think!
/ Loader control like on a JD? #2
On the L-39, the remote joystick has three cables that go to the hydraulic valve block down below the deck to operate the valves. I doubt if you could accomodate this kind of setup, the only way you could with yours would be to move the entire valve box to where you wanted it and replumb it from there. Sounds like a major hassle though.
2002 Ditch Witch 1230H Walk-Behind Trencher (A64553)
2002 Ditch Witch...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
Used Landpride GR1525 Stump Grinder
Used Landpride...
JMR 72in Dual Cylinder Grapple Rake Skid Steer Attachment (A64553)
JMR 72in Dual...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
Hensley 16in. Bucket with Teeth Excavator Attachment (A64194)
Hensley 16in...
