loader bucket wont curl back
/ loader bucket wont curl back #1
JackMentink
Rolla, Missouri
2008 Montana R3644
I have a montana r3644 and when I was pushing some snow for an extended period of time (2 hours) in some pretty cold weather for Missouri (10 degrees with 20 mph winds), the loader joy stick wouldn't allow the bucket to curl up. The joy stick is leaning in twords the seat at a strange angle and the bucket wont curl up. Everything else works great. Can lift the bucket, 3 pt works up and down. Any body ever have this happen.
The loader joystick is the type that if you move in front back it raises and lowers the bucket and if you move it side to side it curls the bucket.
Any solution or word of wisdom from anybody?
/ loader bucket wont curl back #2
If your joystick is stuck in the curl position, it might be that the linkage has come loose and the joystick is jammed. Does the bucket curl down or is there no curl at all. If the joystick is not stuck, you might try reseating your quick connects. In the cold weather, one might have popped loose and this will lock up the bucket.
/ loader bucket wont curl back #3
Those joystick valves are spring centered, so if it does not return to the center, either the spring inside the valve is broke, or the spool for that function is jammed. or the pins have come loose on the end of the spool.
/ loader bucket wont curl back #4
Check the linkage connections. One may have come loose. Used to happen quite frequently on my Kubota.:D
2021 BOBCAT T66 R SERIES SKID STEER (A62129)
2021 BOBCAT T66 R...
Reynolds 8CF Scraper (A64047)
Reynolds 8CF...
40' CONTAINER (A62131)
Like New! Low Hours! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Low...
Street Sweeper (A60352)
Street Sweeper...
207277 (A52708)
207277 (A52708)
