Loader Brackets needed
/ Loader Brackets needed #1
RAH5590
I need Great Bend 2140 or Bush Hog M446. I have a new Great Bend 2140 (which is the same as a Bush Hog M446) and plan to put it on a 4 wheel drive JD 2755. Neither make brackets for the JD2755 and I don't want to pay over $900 for a set that I will be modifying.
Does anyone know of some place I can contact that may have used set. Salvage Yard?? or make be you have at set or one that I can copy..
rah5590
/ Loader Brackets needed #2
I would try a dealer's service department. Many of them have older & pull-off equipment sitting around. Also for a coffee & donut they'll probably let you take pictures and measure to your hearts content. Good luck.
Andy
I have been checking with the Local dealers.. Most are small and don't have much.. Will headed down to the lower part of GA in a few weeks, will stop by a few of the larger dealers then..
Still surprised that the savage yards don稚 have any.. Have seen lots of tractors with parts of loaders head that way..
UNUSED IRANCH MINI SEMI-AUTOMATIC QUICK CHANGER (A62131)
UNUSED IRANCH MINI...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
2016 KUBOTA SVL95-2S SKID STEER (A62129)
2016 KUBOTA...
2004 Peterbilt 357 Tri-Axle Dump Truck (A61568)
2004 Peterbilt 357...
2002 Hyster C330B Tandem Smooth Drum Roller (A61567)
2002 Hyster C330B...
KUBOTA L2246-65" PIN ON BUCKET (A62131)
KUBOTA L2246-65"...
