CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 9,341
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
Unloaded drop is perfect
Is this the best solution?
Northman Fluid Power In-Line Hydraulic Flow Control Valve with Reverse Free Flow 8 GPM, 3000 PSI, 3/8in. NPT Ports, Model# TCVT03 | Adjustable Flow Valves| Northern Tool + Equipment
Loader is an Allied 195 Controlled through a three spool 8gpm valve (2 spools used) 3/8th pipe/ #12 orb fittings, PB to 3ph etc..etc...
I wouldn't care to give up the unloaded drop speed, but increased sensitivity of loaded drop speed would be safer and better all around.
suggestions? (longer levers?)
