Loader attachment
/ Loader attachment #1
Anonymous Poster
Epic Contributor
Has anyone made a bucket for a FEL small like a backhoe bucket. Generally compact tractors can't dig easily in compact ground with a 5'-6' bucket even with teeth. I would like to make a bucket 2'-3' bucket with teeth for this purpose. Should I start with a standard bucket and cut and weld to it, or start from scratch? I've seen these kind of attachments for skidsteers.
/ Loader attachment
There is an attachment called a "Rooter" bucket made by Kasco which is very much like what you are describing. It funnels down to about 1' at the nose, with digging teeth. Very heavy duty, including the price quotes I have received (>$1000).
/ Loader attachment #3
I don't see why you couldn't do that. If you made it from scratch, you could also have it extend below ground level so to speak. If you utilize a quick disconnect, the bucket could be hung by trussed rods to leave the sides open for
the operator's vision.
I've been thinking about a similar project but in reverse. I'd like to build an 8', 10' or even wider aluminum bucket for handling light weight materials like mulch. I'd probably end up at the same weight as a regular bucket but with more capacity. It'd look ridiculous hung on a 30hp Kubota, but it should work.
/ Loader attachment #4
That would be great idea have a huge lightweight bucket. I can see uses for both a small actual digging bucket and a large bucket for mulch leaves twigs grass clippings.
/ Loader attachment #5
<A target="_blank" HREF=http://www.lackender-fab.com/index.htm>http://www.lackender-fab.com/index.htm</A>
I would love one of these. It would hook right up to my Unihitch.
Spence
/ Loader attachment #6
<font color=blue>That would be great idea have a huge lightweight bucket</font color=blue>
I had the same thoughts last year, and came up with my poor man's solution using plywood. You can see my embarrassing contraption in and <A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/5-63503-HarvScoop2.jpg>actions shots. It was a "proof of concept" prototype, but you might enjoy reading the <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=implement&Number=63500&Search=true&Forum=All_Forums&Words=large%20scoop&Match=Entire%20Phrase&Searchpage=0&Limit=50&Old=allposts&Main=63500>whole discussion</A> that ensued.
/ Loader attachment #7
That's sort of the idea or even in forward facing.
/ Loader attachment #8
Here's a link to the Kasco Rooter bucket.<A target="_blank" HREF=http://www.kascomfg.com/ROOTER.jpg> Kasco Rooter</A>
And their homepage <A target="_blank" HREF=http://www.kascomfg.com> Kasco </A>
They have some really neat stuff.
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - Tier 2 - Irrigation Takeout (A63689)
Kubota V3600-T-E2...
Informational Lot - Financing (A63689)
Informational Lot...
2019 FREIGHTLINER 122SD 6X4 T/A TRUCK TRACTOR (A59912)
2019 FREIGHTLINER...
Coats 90X-AH-L Tire Changer Machine (A61573)
Coats 90X-AH-L...
Misc. Tires (A61573)
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
