Loader as excavator???
/ Loader as excavator??? #1
Raul-02
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
Anyone used a ripper to break soil so as to use the loader as an excavator?
Multiple ripper passes to break the soil then turn around and dig in with FTL??
/ Loader as excavator??? #2
With teeth on the bucket I don't have to use a ripper here in the hard red clay:
/ Loader as excavator??? #3
I used to use my tiller to break up the grass/soil, then scoop it up. The tiller not only cut into the dirt, but made it nice and loose. No big dirt chunks.
/ Loader as excavator??? #4
A tiller works great. A box blade works pretty well too.
/ Loader as excavator??? #5
a toothbar like the pirahna makes digging much easier, Some on here say you cant dig with a tractor but i have dug and moved tons of dirt with mine,
/ Loader as excavator??? #6
I'd box blade it to a pile then scoop it. Geometry get's funky/high stress with the loader once the pins get below the bottom of the tires.
I have the ripper no box blade, & no teeth, It's a nice big ripper. Makes a real mess of the lawn ;-0
got a Tiller too, hadn't thought of using that. .
/ Loader as excavator??? #8
I have used my 3PH mount tandem disc to work up the soil and then use the FEL to haul it away. Disc also acts as counterweight while doing this also.
/ Loader as excavator??? #9
Old post but I use a ripper for our food plots to turn the land then til. If I need to dig, I grab the mini, pile it up and then tractor to move it if needed.
/ Loader as excavator??? #10
Less than $200 and I can use anything that goes into a 2" receiver...👍
/ Loader as excavator??? #11
I used one of the rippers from TSC to get the ground started, then just used my plain 6' bucket to dig many projects over the years. This was for my storm shelter build about 10 years ago. Ours is a lot of red clay and layers of chert rock - with a few really big rocks peppered thru. Only had to hire a backhoe to do my footer and utility and french drain trenching. I've used and abused my little 4110 over the years but it has done a BUNCH of work for me.
/ Loader as excavator??? #12
How's about stripping topsoil for a gravel pad build? Probably going down 12". I'd like to do so this spring with my Bobcat 2025. Regular FL7 loader, no teeth. I have done some such stripping already with machine. Didn't seem to struggle. Don't want to stress hydro system though.
/ Loader as excavator??? #14
I dug two ponds with the loader bucket with no tooth bar. Angle the bucket right and the right size tractor will doze right thru clay. This bucket is 7 foot wide.
hugs, Brandi
/ Loader as excavator??? #15
That's how I've done it in the past. The FEL is not an 'excavator'... scoop and lift. It's how I levelled for the pad of my 5-bay shed.
My tiller has also been used to 'turn in' (mix) mulch and I'm very popular with the local Community Garden for breaking new ground for their garden beds. It's been a versatile implement.
Mind you, you use what implements that you have, I suppose.
/ Loader as excavator??? #16
Hi Brandi! So many FF friends here.
10ft Fork Extensions (A64553)
10ft Fork...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
New/Unused ATS EPC40 Plasma Cutter (A65583)
New/Unused ATS...
2011 Nissan Murano SUV (A64557)
2011 Nissan Murano...
2007 Polaris Ranger XP (A65579)
2007 Polaris...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
