loaded tires
/ loaded tires #1
porta mill
i have a john deere gator 6x4 in the snow it worthless unless there is a load in the dump box and when there is a load in the dump box I cannot steer it I was thinking of loading the tires to help weight it down a bit. was wondering if anyon has done this to there gator
/ loaded tires #2
I don't know if gator tires will hold enough ballast to make it worthwhile, but any ballast is good for traction. As you've found out, adding a load to the bed louses up the steering ability by making the front-end light.
I think in your case I'd shoot for chaining up the 4 rears for traction...
My .02
Lunk
/ loaded tires #3
Maybe you could hang some barbell weights on the front bumper if you have a bumper. Keep your bed loading close to the cab and it should be in front of the back tires. That should distribute the weight to both the front and rear. Maybe some big ole agressive R1 type ATV tires would help too. I did see one gator with those on it and it looked like it would go in the mud, dont know about the snow as they dont seem to have much ground clearance.
2020 MACK PINNACLE (A60736)
2020 MACK PINNACLE...
2020 BOBCAT T770 SKID STEER (A62129)
2020 BOBCAT T770...
2019 Freightliner B2 School Bus (A59230)
2019 Freightliner...
2025 METALIUM INDUSTRIES 14 T/A GOOSENECK ROLLOFF TRAILER (A60736)
2025 METALIUM...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2008 Ford E-250 Cargo Van (A59230)
2008 Ford E-250...
