Tires Loaded tires question.
   / Loaded tires question. #1
smokedtires
Lysander NY
Hello all, I'm new to this forum though been reading thru many topics for a short while.
I just picked up new to me a JD4100 with 247 hours on it, that has Ag tires that are loaded with antifreeze (as told by previous owner) to help ballast the JD410 FEL. My question is, assuming I don't wear out the tires for a long time, is there a time frame where it's recommended to have the tires drained or the antifreeze changed? TIA /forums/images/graemlins/smile.gif
   / Loaded tires question. #2
Never heard of Antifreeze going bad.
As long as it maintains its 'weight' and doesn't freeze, seems it would do its job.
That sounds great. I figured I'd ask just to be safe /forums/images/graemlins/wink.gif Thanks.
   / Loaded tires question. #4
The good thing about having the tires filled with antifreeze is now you dont have to change the air every season either. /forums/images/graemlins/grin.gif
Just messin with you. Welcome aboard.
   / Loaded tires question. #5
You should be good to go for your lifetime plus some. Antifreeze in tires won't break down like it does in an engine. There are no heat/cool cycles in the tires.
One thing you will want to watch is if you get a leak. Antifreeze can be deadly to animals if they ingest it.
Other than that, enjoy your new to you tractor /forums/images/graemlins/smile.gif
Thanks guys. I'll check this off as something I won't have to worry about until I need to replace the tires down the road.
Cheers!
   / Loaded tires question. #7
Bummer, You mean I don't have to rotate the air in my tires each month. I've built these air chuck transfer hoses for nothing.
   / Loaded tires question. #8
</font><font color="blue" class="small">( Bummer, You mean I don't have to rotate the air in my tires each month. I've built these air chuck transfer hoses for nothing.
)</font>
Where do you keep the excess air when rotating it from rear to front?
   / Loaded tires question. #9
I don't keep it. I transfer it. You need wheels with dual valve stems 180 degrees oposite each other. You need two 20 foot air lines with locking chucks. One line has inserted into it one air pump, one sight glass and one dye injector. Hook up a line to each valve stem and turn on the pump and dye injector. When you see dye in the sight glass before the pump (the dye injector is after the pump), you're done; the air has been moved.
/forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif
   / Loaded tires question. #10
</font><font color="blue" class="small">( I don't keep it. I transfer it. You need wheels with dual valve stems 180 degrees oposite each other. You need two 20 foot air lines with locking chucks. One line has inserted into it one air pump, one sight glass and one dye injector. Hook up a line to each valve stem and turn on the pump and dye injector. When you see dye in the sight glass before the pump (the dye injector is after the pump), you're done; the air has been moved.
/forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif )</font>
How do you address the problem of differential pressure between the rear bleeder valve and the diagonal dye injection pump outlet feeder. It would seem that the lesser of the two pressures would be less than the minimum allowable residual pressure, but obviously, only when the locking chuck valves have been released does this really matter.
2013 GMC 3500 HD Service Truck (A50515)
2013 GMC 3500 HD...
John Deere 7130 (A50120)
John Deere 7130...
2015 Freightliner M2 Cab & Chassis (A47384)
2015 Freightliner...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2007 STERLING L9500 TANDEM AXLE DAY CAB (A52141)
2007 STERLING...
2017 John Deere HPX615E Gator Utility Cart (A51691)
2017 John Deere...
