Loaded Tires, or 3PH Weight Box, or Both?
   / Loaded Tires, or 3PH Weight Box, or Both? #11
Well it's already been said but I will re-affirm - Load the tires first. And I agree w/ bdog - load all four.
You don't mention if you're getting a FEL also but for ours it recommended counterweight in addition to already having loaded tires so there's that to consider as well.
Second (as I am not familiar with that model) - see about any adjustment in the rear wheel width (Our Kioti had adjustable width rims but only with Ag tires). If there is no adjustment in the wheels themselves then look into spacers.
Third - unless you just really really want a ballast box, I would instead suggest getting a heavy implement. A Box scraper / Box Blade is usually the most favored because it is heavy but not too long as to hinder maneuverability. A ballast box will never be more than a counterweight and tool carrier but you can at least do work with a Box Blade. And since you mention working on a road it might be pretty useful anyway.
Best of luck what ever you do.
   / Loaded Tires, or 3PH Weight Box, or Both? #12
I'll also cast my vote for having a box blade hanging off the rear. As N2DFire notes, you can do work with it (quite a bit!). I often use the one on my B7800 as a brake to hold my tractor from moving if I'm hoisting up stuff with the FE; if one has hills then one can use it in cases of emergency; with scarifiers down it can stick pretty good! I've also used my BB as a carrier: flipped around the scarifiers and dropped in some plywood -it'll be held in place by the inside mold board in the rear and the scarifier tines on the front, creating a nice bottom/shelf).
   / Loaded Tires, or 3PH Weight Box, or Both? #13
Loaded tires first and a box blade if you need more weight.
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
2013 Nissan Rogue SUV (A56859)
2013 Nissan Rogue...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
2013 Ford Edge Limited AWD SUV (A55853)
2013 Ford Edge...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
