Tires Loaded tire weight
   / Loaded tire weight #1
THEBUS
Does anyone know how much fluid the rear industrial tire for a TC40 will hold - I am wondering how much weight is added per tire when they are filled.
   / Loaded tire weight #2
Thebus,
I can't tell you to the exact pound, but a good target is about 600# additional per tire. The weight will vary based on the concentration ( if you go with calcium at a 5 pound solution ). The alternatives ( washer fluid and beet juice ) are a bit lighter in weight.
   / Loaded tire weight #3
<font color=blue>The alternatives ( washer fluid and beet juice ) are a bit lighter in weight. </font color=blue>
At 11 lbs/gal, Rim Guard (beet juice plus some additives) is basically the same weight as Calcium Chloride solutions. Rim Guard is heavier than some of the weaker CaCl solutions.
John Mc
   / Loaded tire weight #4
I believe the TC 40 industrial rear tires ar 17.5L-24 The hold 55 gal when filled to 75%. Filled with Rim Guard ("beet juice") at 11 #/gal this would be 605 lbs. I believe this would be about the same for some of the stronger CaCl solutions out there, but I don't have the exact weights for those solutions.
John Mc
   / Loaded tire weight #5
Here is a <A target="_blank" HREF=http://www1.uwex.edu/ces/pubs/pdf/A3401.PDF>link</A> to a pdf file which gives a very in depth look at ballast, and includes a table at the bottom which shows the amount of weight added with varying concentrations of CaCl2 in H2O in many different size tires. It lists my rear tires (18.4 x 30's) as holding 742 lbs of plain water (I have water and antifreeze which is about the same weight as plain water) per tire, and my front tires (12.4 x 24's as holding 250 lbs each. Hope I don't have to change these any time real soon./w3tcompact/icons/frown.gif
   / Loaded tire weight #6
"Does anyone know how much fluid the rear industrial tire for a TC40 will hold - I am wondering how much weight is added per tire when they are filled. "
The attached file is an Excel Spreadsheet saved as text.
Columms A, B and C list tire size, gallons added and approximate weight added, respectively.
For those of you who have Excel, I'll attach that file in the subsequent post
   / Loaded tire weight #7
The Excel spreadsheet of the same data listed in the text attachment (previous post).
I had to "Zip" this file to post it.
The file will download to your local hard drive and you'll have to "unzip" it to read or save. Although the file was virus scanned before uploaded, always virus scan it after a down load...it's sorta like me handing you a gun and saying <font color=red>"Don't worry, it's unloaded..."</font color=red>
By the way, this data came from a web link another TBNer had posted on another forum. I don't recall the web site or the original poster, but I like to ensure he or she is recognized for their input!
   / Loaded tire weight #8
I suppose that it all depends on what they are filled with. <A target="_blank" HREF=http://www.tractorsmart.com/Farm_Tractor_Liquid_Tire_Ballast.htm>Here</A> is a webpage that gives tire size and weight added when filled with water.
Thanks for all of the replies and great information. I have another question. Do the boomer tires have tubes or are they tubeless?
2005 Interstate 7x14 Trailer (A55973)
2005 Interstate...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A55302)
2017 Ford F550...
2004 FREIGHTLINER CL120 TANDEM AXLE DAY CAB (A57880)
2004 FREIGHTLINER...
2012 Ford Econoline Cargo Van (A56858)
2012 Ford...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
