Loaded tire pressure gauge
/ Loaded tire pressure gauge #1
JKeane
Massey Fergusen MF1758
Has anyone come across a decent gauge for reading pressure on loaded tires? I can seem to find one that is easy to read and accurate.
Thanks.
/ Loaded tire pressure gauge #2
Loaded tires require a small amount of air to allow for give and flex. Simply roll until the valve stem is at the top and use a standard tire gauge. I run about 25-30 pounds.
Thanks. I've tried that but seem to get a lot of liquid (washer fluid) spitting out of the valve. Maybe I need to let more bleed out.
/ Loaded tire pressure gauge #5
You can purchase stick style gauges meant for use with filled tires. These are spring loaded so you must read pressure with gauge held on the stem.
Another option is gauge with a foot or two of hose between stem connection and gauge. Keep gauge higher than valve stem and in theory fluid never gets to the gauge.
/ Loaded tire pressure gauge #6
I roll the tire so stem in at top, then give it a short shot of air pressure to clear the liquid. Some liquids will ruin a tire pressure gauge, so if necessary I can always bleed out excess pressure.
In fact i just bought an analog 0-60 air pressure gauge($10) with a bleed plunger on the side of the tube. Now it's much easier to maintain 8-12 PSI in my ZTR lawn mower tires and tractor tires.
/ Loaded tire pressure gauge #7
I had a tire gauge designed for filled tires, it didn’t last long. I blow air in with the stem at 12 o’clock and still end up with a mess.
/ Loaded tire pressure gauge #8
Still using the same pencil gauge I've used for 15 years on loaded tires, not worrying about where the valve stem is when it's used.
Occasionally I grab it to check regular tires...and it works just fine on those, too.
/ Loaded tire pressure gauge #9
You have to be QUICK when adding AND removing your air Chuck.
I have 16 antifreeze mix fluid filled tires on tractors & Zero mowers here on the farm.
Napa makes a springloaded gauge for liquid that works great.
You have to keep it applied on stem to read it.
/ Loaded tire pressure gauge #10
Normally I am quick at adding air and checking the pressure. This time because the gauge didn’t work I had to let air out.
/ Loaded tire pressure gauge #11
Man no good (n)
I never drain.
That looks like calcium chloride :mad: Which I’d never use.
/ Loaded tire pressure gauge #12
It’s Rim Guard. I didn’t want to drain it but aired the tire up to much because of a bad gauge.
/ Loaded tire pressure gauge #13
Does it matter? Isn't pressure form the same vessel the same whether it is liquid or air?
The liquid won't compress like the air will so when you run over a rock the tire will take a lot more abuse without air. That's the way I was told....
/ Loaded tire pressure gauge #14
I believe you were told correctly. (y)
Thanks for the question. I think you are correct, however, what matters is that the fluid gunks up the works of most "regular" tire pressure gauges.
Thank you.
Thanks for the reply.
Thank you.
/ Loaded tire pressure gauge #19
Yep... check with the stems up if you are worried about fluid coming out. I just use a standard dial pressure gauge on mine without any problems. Mine are about 80% filled with used antifreeze from a truck shop 20 yrs ago, and they were glad to get rid of it, since they didn't have to pay the disposal fee.
REDDICK OFFSET DITCHER (A63291)
REDDICK OFFSET...
PITTSBURG 2R CULTIVATOR (A63291)
PITTSBURG 2R...
Hydraulic Stump Bucket Mini Skid Steer Attachment (A61572)
Hydraulic Stump...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
Kivel Quick Hitch Skid Steer Attachment (A61572)
Kivel Quick Hitch...
Caterpillar Information Guides (A63117)
Caterpillar...
