seacap04
How do you ck air pressure in loaded tires without filling pressure guage with rim guard? I rotate tires till stem is at top of tire.
. . . I will put just a blast of air into the valve to clear the stem, and then check. . .
they have those air gauges just for liquid tires here Milton Tractor Tire Gauge For Fluid Filled Tires, 5?0 PSI, Model# S-928 | Air Chucks Gauges| Northern Tool + Equipment
Get a dial gauge. They are driven by a Bourdon tube. Such has no problem with liquid. Even so, with CaCl there could be corrosion issues which would benefit from rinseout by repeated measurement of water pressure after each use on the salt. Other tire solutions are MUCH less corrosive. ... but you should always be alert to the possible formation of crystals as a solution drys. Rinse is good.How do you ck air pressure in loaded tires without filling pressure guage with rim guard? I rotate tires till stem is at top of tire.
Futile. My tires are full.valve stem at the top.
either hit the valve with a nail to clear it.. or puff a lil air in to clear it. both will clear the residue in the body of the stem.. I prefer puffing a lil air in.. etc..
then use you gauge.
works both ways..
