Loaded the rears on the 3320
   / Loaded the rears on the 3320 #1
Cocre
Sandy Run, SC
'06 John Deere 3320
Loaded the rear tires on the 3320 this morning, 2 gallons of antifreeze and the rest water in each. What a difference it makes. I had been dissatisfied with the R4s being able to back the 3320 out of a drainage collection basin at the end of the drive way. The deep loose sand always just gave it a fit. Often I would have to dump half the load in the FEL and wiggle my way back out. With the loaded tires out she comes.
I always thought the 1000 lb backhoe was sufficient counter weight for the loader, but man was I wrong. The loaded tires have turned this thing into a beast. I was able to do in 15 minutes what had been taking 30. Should have done this two years ago. Gosh, I love my tractor.
   / Loaded the rears on the 3320 #2
Amazing isn't it? How much more traction your tractor has, and how much better it feels. I contrast the day the tractor was delivered, with the dirt work I done this morning. On the day it was delivered, I went to the gravel pile just for fun, and lifted a bucket of gravel, just to remind myself how worthless a tractor without proper ballast and loaded tires is. And not only worthless, but "scary" as well. The tractor bounced all around with the slightest movement with a load on the loader, now it is very stable.
James K0UA
   / Loaded the rears on the 3320 #3
So you put anti-freeze and water in your tires and then do you fill them with air? I could really use some weight on the back of my JD 4200
I rolled the valve stem to the top after adding the antifreeze, then filled them with water using an adapter I bought from Gemplers. I let any excess water bleed out and then put 20 psi of air in the remaining space. I figure the tires are about 70% or so full of water/antifreeze.
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52748)
2017 Ram 5500...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
2005 Appalachain 2 Axle Fender Trailer (TITLE) (A50774)
2005 Appalachain 2...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
