Lk3054 power steering failed
/ Lk3054 power steering failed #1
Nrowland
I've owned a 99 LK3054 for about 2 months. I have been doing nothing but working on the thing. Started off with small leak of hydraulic fluid below clutch housing and found it to be a simple oring in the bottom of the powersteering unit. Too bad I had to have the tractor split to figure out the culprit first. Thought everything was fixed and used the tractor about 30 min when the power steering stopped. Could barely budge the thing. Decided to pull it in front of the garage by lifting the front with the loader and turning wheels when needed. About the time I made it to the garage hydro fluid was gushing out what looked like a port on the back underside of the starter. Anyone have any ideas. Has not been a very good experience with kioti thus far.
/ Lk3054 power steering failed #2
Could be AUX valve is energized and dead heading.
/ Lk3054 power steering failed #3
Nick, this is Kathy from Branson. You've been sharing wonderful info via txt for the last few days. Dummy me accidentally deleted your messages!!! And Charlie has a question. Would you plz call or txt? 417 three three seven two oh 22 Thx!
AUCTION STARTS HERE @ 9AM (A65053)
AUCTION STARTS...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
Aluminum Mermaid (A65583)
Aluminum Mermaid...
(4) Ratchet Straps (A65583)
(4) Ratchet Straps...
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
