LK3054 Large primary air filter
   / LK3054 Large primary air filter #1
ron45
N.M.
Kioti LK3054XS
What color should that larger air filter be? AND, if it needs cleaning, would alcohol be a good rinsing agent?
Thank you mucho,
Ron
Well that is simple enough. I initially thought of alcohol because our water is pretty hard here. I can get distilled water if need be. Do you know of a reason to avoid the alcohol idea?
Also you didn't mention air.... is that to be avoided with this filter? Thank you Billrog for taking the time to help.
Ron
   / LK3054 Large primary air filter #4
If you use compressed air, blow from the inside out so as to not further in-bed the debris. When mine becomes fouled enough to need cleaning, other than blowing it out, I replace it
   / LK3054 Large primary air filter #5
Ron I blow mine out with air as Patches described in dusty conditions on a daily bases. I think the book said not to exceed 60 psi. If you stick a light bulb in it and can't see any light out side of it either wash or replace it. It's not recommended to was more than a few times and it must be thoroughly dry before using.
2005 John Deere 310G 4x4 Extendahoe Loader Backhoe (A55851)
2005 John Deere...
2005 Jeep Wrangler 4X4 SUV (A56859)
2005 Jeep Wrangler...
CUMMINS 230 KW GENERATOR (A57192)
CUMMINS 230 KW...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2013 Ford F-150...
2006 Mac 35ft Tri-Axle Dump Trailer (A55852)
2006 Mac 35ft...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
