LK3054 Large primary air filter
   / LK3054 Large primary air filter #1
ron45
N.M.
Kioti LK3054XS
What color should that larger air filter be? AND, if it needs cleaning, would alcohol be a good rinsing agent?
Thank you mucho,
Ron
Well that is simple enough. I initially thought of alcohol because our water is pretty hard here. I can get distilled water if need be. Do you know of a reason to avoid the alcohol idea?
Also you didn't mention air.... is that to be avoided with this filter? Thank you Billrog for taking the time to help.
Ron
   / LK3054 Large primary air filter #4
If you use compressed air, blow from the inside out so as to not further in-bed the debris. When mine becomes fouled enough to need cleaning, other than blowing it out, I replace it
   / LK3054 Large primary air filter #5
Ron I blow mine out with air as Patches described in dusty conditions on a daily bases. I think the book said not to exceed 60 psi. If you stick a light bulb in it and can't see any light out side of it either wash or replace it. It's not recommended to was more than a few times and it must be thoroughly dry before using.
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2012 Chevrolet Equinox 1LT SUV (A50324)
2012 Chevrolet...
2012 BMW 328i Sedan (A50324)
2012 BMW 328i...
Danuser Digger F-8 (A52748)
Danuser Digger F-8...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
