LK3054 3 point lever
   / LK3054 3 point lever #1
Jimmyb33
SE Texas
Kioti LK3054
The 3 point lever on my LK3054 os getting harder and harder to move. I just about have to stand up from my seat to get enough behind it to move it from the top position (9) to my mowing position (4). Is there a grease point I am missing here? Or is there an adjustment that can be made? This tractor lives outside so it sees all of the elements.
Thanks!
jb
   / LK3054 3 point lever #2
I don't know about your model but on my DK35 there is a grease fitting tucked up under the fender that you can get to from the back. Look up on the right side under the body work and to the right of the top link.
Thanks!, I'll look there this evening.
jb
Is it up torwards the 3pt lever entry to the casting? Or back towards the 3pt arms? I've looked and haven't found it yet. Thanks for the help here!!
Jb
   / LK3054 3 point lever #5
I don't believe our 3054's have that fitting; I've never seen one on mine. I would think your problem lies where the shaft enters the case(hydraulic cylinder[rockshaft] case on top of the differential case, under the seat. I would give that area a good soaking with PB Blaster, or some such penatrant, working the lever;there is no external linkage to this control. This area is pretty tight, so you might have to remove some tin
Thanks patches. I know the area you are talki
ng about. I'll give it a work over this weekend.
Jb
Thanks again Patches. I hit it with some PB blaster and worked it some and it loosened right up.
I sometimes look past the simple solutions and make things more difficult than they realy are. Thanks for the help!!
jb
   / LK3054 3 point lever #8
Not the first time patches sorted out a problem and won't be the last.
Posters like that add huge value to these forums.
Joel
   / LK3054 3 point lever #9
Glad I could help; I've got a post on the JD forum asking for help for a neighbor with a problem, and of course, somebody(etcallhome) stepped up with a test procedure that he got from another site. That is what this site is all about and I think it's great :D
2023 Kubota L6060HST Compact Utility Tractor (A56435)
2023 Kubota...
2012 FORD F-550 SUPER DUTY CAB AND CHASSIS (A58214)
2012 FORD F-550...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2012 John Deere 6170R (A57148)
2012 John Deere...
Adams 5T Pull-Type Fertilizer Spreader (A56436)
Adams 5T Pull-Type...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
