LK2554 leaking oil
   / LK2554 leaking oil #1
rtaylor45
alexandria louisiana
LK2554
:confused:LK2554 leaking oil while engine running, out of dip stick and breathing tube, any suggestions?
   / LK2554 leaking oil #3
The only thing I am aware of to cause that much blowby is the rings are bad or a hole in a piston.
   / LK2554 leaking oil #4
Plugged crankcase ventilation? If not (e.g. rings or piston) it will be costly.
only time it blows off is when I raise rpms up to 2500. seems to be good below that, ran for 6 hours 100 to 1500 rpm and no blow out. is there a cleaner to see if I can clear pistons or rings.
   / LK2554 leaking oil #6
You could do a compression test also. Not sure where the breather is?
KUBOTA KX080-4 S2 EXCAVATOR (A51246)
KUBOTA KX080-4 S2...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2014 RAM 4500 versa LIFT bucket truck (A52377)
2014 RAM 4500...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
(1) HD 24ft Free...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
