LK2554 lacks engine power
   / LK2554 lacks engine power #11
Rebuild the engine.
   / LK2554 lacks engine power #12
Thanks, i opened two of the lines at the injectors, cranked it for a few seconds until i got steady flow of fuel, tightened them back up and it started right up.
Now i have to figure out how to get the clutch repaired.
Never use starting fluid, or you won't have to fix your clutch problem, 'cause your engine will be toast.
Adjust the clutch first, then see where you're at.
   / LK2554 lacks engine power #13
LK2554 leaking oil while engine running out of dip stick and breathing tube, any suggestions?
You're hijacking the OP's thread. You should post in your own new thread, not in the middle of this one.
   / LK2554 lacks engine power #14
Rebuild the engine.
You're referring to the guy who jumped into the middle of this thread, not the OP.
Try leaving the religious quotes in your about me section and not in your signature line.
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
Massey Ferguson 9250 (A55315)
Massey Ferguson...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
202476 (A54757)
202476 (A54757)
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
