Buying Advice LK2552 - used buy advice
   / LK2552 - used buy advice #1
kurtw
Punta Gorda, Fl
Just looked at a used lk2552 with 105 hours, industrial tires. The tractor looks in great shape - the dealer wants $6250 and $1000 for a kioti 62 inch finish mower. Any advise? is this a fair price? I tried all the gears, pto, did not put the pto under load. No oil leakage, started right up. No smoke after it started up. May pull a small box blade as well. Will it have enough power.
Thanks
Kurt
   / LK2552 - used buy advice #2
Isn't this pretty much the same question you asked earlier? If you don't want to put a front end loader on it, it's a pretty good tractor that will do what you say you want to do. The price is reasonable. If you want a FEL, then you need to buy 4WD.
John
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
NEW Wolverine Fixed Mini Excavator Thumb Attachment (A53002)
NEW Wolverine...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
2015 Caterpillar 410L 4x4 Extendahoe Backhoe Loader (A51691)
2015 Caterpillar...
