LK 3504 Tach problem
/ LK 3504 Tach problem #1
grapeguy
My tach stopped working all of a sudden. I pulled the cable end off of the block to check the cable... all seems ok. I spun the end with my fingers and the tach needle jumps. With the cable disconnected, I looked into the housing and noticed that the slot was not turning. Is there something to lube? What would break in the housing mounted to the block? It seems odd this would happen without any warning. One minute it was running and the next dead. Any answers?
John
/ LK 3504 Tach problem #2
I would say there must be a gear in there on the engine?
Can block be removed to be inspected?
That appears to be next step.
Most things that break happen suddenly unfortunately. Mechanical objects have no regard for the human condition.
/ LK 3504 Tach problem #3
There is a tach drive on the front of the engine. It will need to be replaced. We should have stock of them, just give me a call if you need one.
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2016 Kawasaki 62Z7 Articulated Wheel Loader (A61572)
2016 Kawasaki 62Z7...
Caterpillar 320B/BL/BN/LL Excavator Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar...
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
2006 Toro SandPro 2020 Bunker Rake (A61572)
2006 Toro SandPro...
2016 Ford Escape (A61574)
2016 Ford Escape...
