LK 3504 Tach problem
   / LK 3504 Tach problem #1
grapeguy
My tach stopped working all of a sudden. I pulled the cable end off of the block to check the cable... all seems ok. I spun the end with my fingers and the tach needle jumps. With the cable disconnected, I looked into the housing and noticed that the slot was not turning. Is there something to lube? What would break in the housing mounted to the block? It seems odd this would happen without any warning. One minute it was running and the next dead. Any answers?
John
   / LK 3504 Tach problem #2
I would say there must be a gear in there on the engine?
Can block be removed to be inspected?
That appears to be next step.
Most things that break happen suddenly unfortunately. Mechanical objects have no regard for the human condition.
   / LK 3504 Tach problem #3
There is a tach drive on the front of the engine. It will need to be replaced. We should have stock of them, just give me a call if you need one.
KJ (10) Rolls of Hot-Dip Galvanized Field Fence (A50121)
KJ (10) Rolls of...
John Deere 7000 12R 30" Planter (A50515)
John Deere 7000...
2016 GMC Savana (A50120)
2016 GMC Savana...
2017 Dodge Caravan Van (A50324)
2017 Dodge Caravan...
Kioti LK2554 Tractor (AS IS) (A50774)
Kioti LK2554...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
