LK 30 TLB
/ LK 30 TLB #5
3054's a somewhat different animal; less horsepower(different engine), less hydraulic capacity(different pump), same hoe and loader, transmission/shuttle etc. The LK 30 is essentially an upgraded 3054xs TLB
/ LK 30 TLB #6
The LK30 is a CK30 from the clutch housing forward.
/ LK 30 TLB #7
What is the pump output on an LK 30? From looking at the machine looks super similar to my LK 3054XS TLB.
Interesting, looking close at Kioti's website (which is probably one of the worste maintained sites I've ever regularly visited) the LK 30 in the pictures, at least the picture hihglighting the muffler is a picture of an LK3054XS.
I did not know the LK 30's motor is different from mine, when did the change happen? Will the LK 30 hydro pump fit my machine? No problems (knock on wood), just curious.
Thanks,
Joel
/ LK 30 TLB #8
The total hydraulic flow of the LK30 is 12.7 GPM, as opposed to 10 GPM for the 3054. The engine is 91.5cu.in.(1499 cc) as opposed to the 3054's 85.1cu.in.(1395cc), both 3 cylinder. I've looked at the LK30 at Batchelder's and it looks pretty much identical to the 3054, except the LK 30 emblem is chrome rather than a decal. I really think it is an upgraded 3054, as Kioti no longer produces that model.Will the 30 pump fit on the 3054; I doubt it, but who knows???
/ LK 30 TLB #9
Thanks Patches.
PS, your handle makes me smile, I'm 41 years old, when I was 5 I got a stuffed animal and named him patches, the mini-boss (daughter) now plays with that stuffed animal.
Joel
/ LK 30 TLB #10
Thanks Patches.
Joel
Joel, I'm 68, going on 20. You and mini are at prime time;don't let a minute get away from ya;you'll be amazed how fast they grow up:(
/ LK 30 TLB #11
You said it patches, you said it. The mini-boss pulled me aside a couple of months ago and said "Dad, you work too much and you make work more important than the family and that is not right.", took me a month or so, and a few concessions, but will be starting a new job in three weeks.
From the mouths of babes right?
Hope you have a great weekend,
Joel
/ LK 30 TLB
i bought my lk 30 in dec took me till feb to get manuals when i got them thers was one on the tractor one on the bh one on the fel but they all show an older lk 3054 with diff hyd hook up and all is this normal or did i get one pulled over on me
/ LK 30 TLB #13
Check with Rick Wallace, sounds like you got the old manuals with a new machine.
Joel
/ LK 30 TLB #14
All, I just looked at the LK30 this morning 4-24-09. It seems like a sturdy-built machine.
Do you owners have any complaints?
What is the fuel burn?
I live at 9,100' in the Colorado mountains and wondering is 30hp enough?
Thanks all
Keith
/ LK 30 TLB #15
As noted previously I've got the very close cousin, an LK3054XS.
I've been very pleased with my machine, I really like the unique (to Kioti) method of backhoe attachment, it's a four point mount that is easy to take on and off and results in a nice rigid mount that is high and tight against the tractor. I do not have the bars under the tractor as it is nicely integrated into the frame of the tractor.
I'm very pleased with my machine, strong, easy to opperate and I understand the LK30 has a larger hydraulic pump which is a good thing. I think you'd have slightly more HP. I've never wanted for HP, but I use primarily as a TLB, and when hoe is off I use box blade. I can not imagine my machine having trouble with the properly sized mower or tiller.
Again, I am very pleased and would purchase again no questions asked.
Good luck,
Joel
/ LK 30 TLB
cant get the three point hitch to work with fel any suggestions thanx
/ LK 30 TLB #17
I am not sure how yours works, search for threads as this recently came up.
For me, I remove the hoe, I swap my hydraulic lines around so that I cut out the circuit to the hoe. I remove the line from the loader valve to the hoe and remove return line from hoe to hydraulic block and take line from loader straight to the block.
I think you have a slightly different set up and need to turn the valve on the hydraulic block.
Sorry, again do a search, someone just ran into this with a newer machine like yours.
There's nothing mechanically wrong, it's just you need to sort out the settings.
Joel
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2014 Screen USA TROM 6090 Trommel Screener (A61572)
2014 Screen USA...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A64194)
Paladin 12in...
ROADTEC RX700 MILLING MACHINE (A64279)
ROADTEC RX700...
2017 Infiniti QX50 SUV (A61574)
2017 Infiniti QX50...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
