Live pto issue on case ih 245
/ Live pto issue on case ih 245 #1
groni
case ih 245
Hi all im having issues with the live pto not working on my case ih 245, I press the clutch half way but nothing happens, if I press the clutch in all the way the tractor stops and so does the pto. Does my tractor even have a live pto how do I know for sure?
/ Live pto issue on case ih 245 #2
Accordingly to TractorData, live PTO would've been an option. The standard would be a single stage clutch, so when you press it, it stops both the drive and the PTO.
From your description, yours seem to have the later.
It has this set up on the tractor if that helps determine if it is equipped with live pto, all tho the push arm is not hitting the plunger in position 2, I can't tell if its touching in position 1.
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
Case IH 200 50' Field Cultivator (A66285)
Case IH 200 50'...
SDLanch SDLGC80 (A64127)
SDLanch SDLGC80...
3pt 4' Rhino SE4 (A64127)
3pt 4' Rhino SE4...
213063 (A64276)
213063 (A64276)
New Quick Attach Power Spreader (A65579)
New Quick Attach...
