Backhoe LITW Backhoe
/ LITW Backhoe #1
shutt40
Coronado AB Canada
Massey Ferguson 1529
Hi
Is anyone running a LITW 7600 or 7601 off of the tractor hydraulics? I'm trying to figure out if the valve has a power beyond option or only a low pressure return. The documentation says it's a low pressure return line.
Thanks,
Frank
/ LITW Backhoe #2
We sold LITW a while back,we now sell a different Korean backhoe that we plumb off the tractor hydraulics,coming off the pump it must go thru the backhoe valve first then back out to the loader,this is a pressure return not low pressure the LITW works the same way.
As the rep or dealer for LITW to be sure,or if you want another option to the LITW give me a call or e-mail,our curved boom backhoes are awesome machines.
Tommy
Affordable Tractor Sales
"Your Jinma parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
/ LITW Backhoe
Thanks
The manual is a little confusing. It says that the 6600 has a power beyond port, but the 7601 only has a low pressure return. Wouldn't they be different ports? One for a low pressure out and a different port for power beyond out to the loader valve or 3pt?
Frank
/ LITW Backhoe #4
I had a LW-06 Chinese hoe and upgraded to a LiTW BH7600. The LiTW is much , much smoother and just as, if not more powerful. I run it off of a Prince PTO pump that stays on the tractor. Can't say for sure if the LiTW valve body has a power beyond port - never looked, and there is no mention of one in the manual. However, I am going to put a hydraulic thumb on it so this would be good to know.
/ LITW Backhoe
Bob
If you want to run a valve for a thumb just get one that has power beyond and put it first then run to the backhoe valve. From what I have learned the 7600 does not come with a power beyond output. You may be able to run the valve off of the normal output, but there is a chance you will exceed the allowable output pressure. I can't find specs on the nimco valve so I don't know what the max allowable outlet pressure is, but why take a chance. If it had true power beyond it would have two outputs one for power beyond and one for return to tank. I'm going to run mine with just a low pressure return and leave my 3pt disabled when the backhoe is hooked up, won't use the 3pt with the backhoe on anyway.
Frank
CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
CATERPILLAR TL642D...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
2022 EZ-GO ELITE...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
