Little help: International 234 Hydro. Where to start?
   / Little help: International 234 Hydro. Where to start?
Often bush hogging the grilles fill up, they overheat and destroy the engine,
From what I've been told, this is likely what happened.
If it turns out to be more serious than the head gasket, what kind of market is there for parting this out? Or am I better off hauling to the scrap yard?
   / Little help: International 234 Hydro. Where to start? #12
Well, the good news is that these little mitsubishis are easy to work on and relatively simple. The bad news is that parts can be hard to come by and/or expensive. You may be in a situation where it'll be easier or cheaper to get a parts tractor and swap out what is good with what isn't. Getting a parts manual and an IT will make it easier to accurately figure out what you need, then pricing the parts will make that decision for you.
Well, I got all the fluid out of the engine. Had to drop the oil pan as I couldn't get the plug out.
I had tried bumping the starter just to see if the engine would turn. It didn't but not sure if that is starter or engine.
If I put a wrench in front PTO shaft, should the engine rotate? If it does not, is it a parts machine?
   / Little help: International 234 Hydro. Where to start? #14
You mean the crankshaft pulley? It should rotate the engine. Does the starter make a sound like it is trying to turn it over?
There is a PTO shaft on front of engine that drives a pulley at front of tractor.
Starter: all i get is clickclickclickclick.
   / Little help: International 234 Hydro. Where to start? #16
Turn the crankshaft pulley. The lower pulley that runs the fan belt. The same gear ratio that urns your shaft at 540 rpms when the motor is clicking along at 2500 rpms works against you when trying to turn over by hand. If no ability to turn the engine there, remove the starter and turn using teeth on ring gear. Is the battery new? Have you checked voltage? Many times batteries these days will not take a jump. If it does not turn over, you could have seized bearings, fluid in one or more of the cylinders, a seized starter. I'm guessing you inspected the lower end and would have seen something like a broken rod. Notice any discoloration on any of the main/rod caps?
Looking closer at the front PTO, it is attached to the crank pulley, where the v-belt is, by a rubber dampening device. Does that make sense? So it goes: crank pulley bolted to rubber biscuit, rubber biscuit to a flange with a male splined shaft welded to it then a female splined shaft that has about a 10" long shaft with an 8" v-belt pulley on it.
The more I look at it, I think this is something someone added.
So long story short: there's no gear reduction in the way. So THERORETICALLY, if I put a pipe wrench on that shaft and turn clockwise, looking from the front, it should turn?
If not, is it seized or should I try another route?
I'm not going to buy a new battery yet.
I didn't notice anything out of the ordinary looking at the bottom end. I have no experience with these little diesels (they are so little!!!) but know what bad looked like on the bottom end of a small block Chevy.
   / Little help: International 234 Hydro. Where to start? #18
Yes, should turn.
And... It does not.
Oh well.
So IS there any point in parting it out? Where would be my best option? Craigslist, eBay or a more direct format?
Or just haul it to the scrapyard?
   / Little help: International 234 Hydro. Where to start? #20
Dang it. I would check for a tractor salvage yard. They might pick up for free? If you are the curious type... now that you have determined it is a loss and nothing to loose, Pop the caps off the rods/mains. Did you ever pull the injectors to determine if there was water in the cylinders? That would make it not turn over. Could be the piston/rings are rusted to the cylinder walls.
2025 Full Body Zero Gravity Massage Recliner Chair (new/Unused) with High Fidelity Bluetooth Surr... (A59225)
2025 Full Body...
huqvarna trak star 1270 rail demo saw (A56435)
huqvarna trak star...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
2009 IC Corporation PB105 School Bus (A55973)
2009 IC...
2020 DRAGON ESP...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
