Little Deck Project
   / Little Deck Project #1
TMcD_in_MI
NW Lower Michigan
JD 4310
Two years after we moved in, I finally am getting around to building a deck in back of the house. Alas, I didn't get to use the tractor to dig the pier holes - I don't own a 3 pt auger. The rental guys wanted about $200 for an auger-equipped Bobcat, so I dug them by hand, 12 inch diameter and 42 inches down. I told my wife that I should get the $200 we saved to put in my tractor fund, and she agreed!
Tom
Got the concrete poured and the posts in over the next two days... still no tractor work.
Tom
Next came the beams ... still no tractor work. /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
Tom
Finally, yesterday and part of today, I got all the joists nailed together, but I assembled the whole thing two feet away from the house so I would have some hammer swinging room to nail into the ends of the joists. So, when I got it all together, squared up, and braced, I ... ta-da! ... used the tractor to push the whole thing across the beams and up almost against the side of the house. I was pretty stoked. It worked like a charm.
Tom
   / Little Deck Project #5
Nice looking project, and glad you found a use for the Deere.
   / Little Deck Project #6
Tom,
Did you use the sonotube all the way down the hole for your footings. I always thought that those were used above ground or in an excavation area, and that if you had a tight hole they weren't needed. But that's just me thinking out loud, as I have yet to use them. Great looking deck! and great idea about leaving the extra room for the hammer.
</font><font color="blue" class="small">( Tom,
Did you use the sonotube all the way down the hole for your footings. I always thought that those were used above ground or in an excavation area, and that if you had a tight hole they weren't needed. )</font>
I did use them all the way down. I thought it would be easier than trying to dig just the right diameter hole for a snug fit on the tube and then building bracing for the short section of tube that would stick out of the ground. I looked at my county's recommendations for deck building, and they showed the piers sticking out of the ground a bit, so I figured I'd better do it that way. I believe it's to keep the bottom of the post and the bracket as dry as possible.
Tom
   / Little Deck Project #8
</font><font color="blue" class="small">( still no tractor work. /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
Tom )</font>
=====<font color="orange">========= </font> =====
I know the feeling.
I'm building a small 6x6 deck with 2 steps
and all the time I'm hammering and sawing away on it I keep thinking this thing is robbing me out of a bunch of seat time.
LOL
   / Little Deck Project #9
TM - I'm working on my deck right now too. Why did you use a beam so close to the house? I just used a ledger board bolted to the rim joist on the house. I then only needed one beam 13 ' from the house, it sets on 6x6 posts.
Of course I didn't get to push my deck around with the tractor, darn!
   / Little Deck Project #10
TMcD,
that sure brings back memories. my first
deckwas built with a hammer, it took about
three weeks for my arm to get back to normal.
that is when i bought a nail gun. all my projects
have been much easier since then.
oh, yes, nice looking deck.
good luck with your projects.
accordionman
wlbrown
2020 Bell B30E Off Road Dump Truck (A53117)
2020 Bell B30E Off...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
1985 International 1954 Grain Truck (A53117)
1985 International...
