List Some Design Flaws On Your Tractor.....Me First !
   / List Some Design Flaws On Your Tractor.....Me First ! #51
About the only comfortable seat I have had on a tractor is the one on my 5500TLB. No suspension, but LOTS of padding. And suspension isnt really needed on a 18,000# slow moving machine. And it has 20" fronts, so that helps too, but is VERY smooth to operate, even on bumpy ground.
   / List Some Design Flaws On Your Tractor.....Me First ! #52
Yanmar EF453
The tractor has had light use (about 150 hours in four years) and the only design issues that spring to mind are:
A) indicator lights on mud guards vulnerable - I've broken 2 off slashing around trees and bush
B) fuel tank behind seats make it difficult to access hydraulic controls from back of the tractor
C) no tool box
Otherwise first rate tractor
   / List Some Design Flaws On Your Tractor.....Me First ! #53
I have a couple old Zetors. I have serious issues with them. They are too heavy too balanced and pull too well. The transmissions are too simple. Seats are worn, paint is faded. hydralics all over the thing with too much capacity.
Drink holder and lunch box holder is the fender well and inside tool box. The only music is valves tapping. I should trade for a light weight pretty tractor for my front yard.
   / List Some Design Flaws On Your Tractor.....Me First ! #54
:laughing:
   / List Some Design Flaws On Your Tractor.....Me First ! #55
No heated seat, missing keyless entry, would love auto climate control and laser guided cruise.
Aside from those features it would have been nice to have the dome light come on when you open the door.
   / List Some Design Flaws On Your Tractor.....Me First ! #56
JD 50x5 Series:
1. More under-armor to protect FEL hydraulic connections, PTO cables, wires, hydro lines, hydo filter, etc...
a. Or relocate FEL hydro connection so they are not hanging down under, Vulnerable spot!
2. THe FEL control stick "Stand" is located and/or angled to far forward and blocks access to getting on the tractor from the right side, without dancing and sucking in my gut (hey! what gut?!). Maybe this isn't a problem in India where they built it. They could of easy angled it straighter up or moved it back and formed the actual control stick coming out of it to be in the same location as it is now.
3. Not so much a design flaw, but in the "come on, how much would that of cost!" department:
a. Horn would be nice.
b. How much extra would sliding 3 point extension arms of costed?
c. A 4WD is "engaged" light. ( Trade if for the PTO indication light. Come on! I can see or hear that!")
i agree with 1and definitely 2
I will chime in about the suspension seat on my E. I'm pushing 220 and I regularly bottom it out and use my kidneys to stop the descent. I have never operated a tractor with an air seat and really didn't feel I needed to spend 800 dollars for the upgrade. Maybe I should have? The old 4020 has plenty of adjustment that I can't even bounce hard enough on the seat to bottom it out.
i am a little more 230 or so haven't yet bottomed out the seat.
My list
John Deere 5055E
1. key switch is too low- I have to bend way down to find the hole to put the key in.
2. Seems like reverse is way too fast for bush hogging when backing up with 9x3 transmission.
3. boots that goes over shifter levers is way to cheap made.
4. There is no easy way to get on the tractor from left side but in there defense most tractors have this issue.
5. No four wheel drive light when engaged I do not like.
6. No rear work light from factory (This I just could not believe)
7. No drink holder
8. I wish there was more area enclosed by feet like my New Holland.
9. Plastic hood seems like it should be a little better braced especially when opening it.
Other than that I really love the tractor.
4 do you mean RIGHT??
live PTO, just not used to it
   / List Some Design Flaws On Your Tractor.....Me First ! #57
JD 50x5 Series:
My list
John Deere 5055E
7. No drink holder
   / List Some Design Flaws On Your Tractor.....Me First ! #58
The Black seat has got to go.
   / List Some Design Flaws On Your Tractor.....Me First ! #59
On mine, the tiny plastic petcock mounted in the open for draining coolant was a poor choice. First thought, wow they really are trying to make maint easy. Not long later, wow that branch I just backed over clipped the drain (sheared it off) and now I am losing coolant rapidly.
Even the engineer knew it was a bad choice, as they added a little metal plate to protect it. Too bad it only was good for a frontal assault.
   / List Some Design Flaws On Your Tractor.....Me First ! #60
The only flaw in my Kubota B2320 is the lack of a "Warning, fold your ROPS down before pulling into the garage, you idiot!" alarm.
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
500 GALLON S/A FUEL TRAILER (A52708)
500 GALLON S/A...
2019 PETERBUILT 579  DAYCAB (A58214)
2019 PETERBUILT...
1269A (A58374)
1269A (A58374)
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
408 (A52708)
408 (A52708)
