Tires Liquid in Tires
   / Liquid in Tires #31
John,
I recently filled the rear tires on my little Yanmar 1700. It is 2wd and you need all you can get when pulling a 5' scrape blade with crush and run flowing over the top.
I purchased the air stem adapter from TSC for about $10.00 and used the antifreeze that is environmentally safe. I can't remember the name, but suposedly will not hurt animals and the such. Purchased at Advance Auto. I had a drill pump that I used to transfer the antifreeze and then you connect to your garden hose and fill.
I haven't read the other threads; might have already been mentioned.
Fig
   / Liquid in Tires #32
Gentelmen,
I just put rimguard in my 2210 rears. I've seen rims replaced becasue of CaCL and didn't want to deal with the hassle 5-15 years from now. It took some time on the phone finding a dealer, I ended up taking the tires and driving 30 miles to get them filled at a small tire shop.
I asked a local Kubota dealer why he didn't carry Rimguard and he said you couldn't mix it with other products, so coupled with the low demand and high price, they still use CaCL about 90% of the time.
Price was $3 gallon, we broke the seals and dumped in about 10 gallons per tire. It's pretty thick reddish stuff, so it very well could be the beet juice product gpod was talking about earlier. I think RimGuard is headquartered in Michigan as well, so it makes sense.
Hope this info helps a little.
   / Liquid in Tires #33
Does anybody know of a rimguard dealer in Texas?
Thanks,
D.
   / Liquid in Tires #34
I had a 3520 with cab, i put Fluid in all the tires, front and rear....I lost a lot of power when i did that, especially going down the road at full speed....thought the tractor had problems because of lack of power, had it put on the dyno and checked over....came to the conclusion that it was all the added weight. I now have a 4720 and went with wheel weights on the rear, and the loader is all the weight i need on the front....just something to think about when adding fluid.
   / Liquid in Tires #35
I am going to price wheel weights for both my 4520 cab and 5525 cab.
How much weight can I put on each?
How much did it cost you?
Thanks,
D.
   / Liquid in Tires #36
Methinal doesn't hurt your rims,and I'm sure it and water is cheaper. It weighs about same as just water though.
   / Liquid in Tires #37
Real John Deere owners use scotch.
And not any of the blended junk, we're talking single malt.
Then when you get a flat, you just get down there and sip on it. Then the flat don't seem like such a big deal...
   / Liquid in Tires #38
Well now that just seems like a waste,oh,forgot you said john deere owners,ok,makes sense now:D
   / Liquid in Tires #39
John,
Fig
Was the brand "Sierra" for the antifreeze?
Steve
Club Car Electric Cart (A55758)
Club Car Electric...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
1996 Sunflower 1543-38 Folding Disk (A56435)
1996 Sunflower...
