Linoleum garage floor
/ Linoleum garage floor #1
miltrade
Virginia
JD 4200
I have a concrete garage floor. I have tried the various garage floor paints, none seem to work as well as advertised. I was considering trying to lay black linoleum tile squares instead. Seems like they would hold up and could easily be cleaned. Anyone ever tried this?
/ Linoleum garage floor #2
The building I work in has a fair amount of traffic, both foot and wheels. We have a mix of linoleum and epoxy paint. It's almost six years old now. The painted surface looks about as good as the linoleum, and if I had to pick, I'd say the paint looks a bit better. For what it's worth.
Another thought. Linoleum sticks fairly well to concrete, but I wonder how it would stick to previously painted concrete. I've never tried that.
I do think linoleum would make for an attractive garage floor though.
Good luck.
Tom
/ Linoleum garage floor #3
My concern would be how slick it could be with any kind of moisture on it... such as rainwater dripping off the car.
/ Linoleum garage floor #4
miltrade,
My concerns with linoleum, would be that it would get crushed with floor jacks and jacks stands if you plan to use these in the garage. I would think that it would also burn if using torches and welders. It would look nice if it is just to park on. I think I would try painting it again and make sure you etch the surface.
Good luck,
Russ
/ Linoleum garage floor #5
Another problem with linoleum is that it will release if it gets too wet or allowed to stay wet for a time. Have seen many times where linoleum on kitchen floors, bathrooms, laundry rooms, etc. has separated from the floor if water was allowed to leak on it for very long. Maybe there is some kind of super adhesive to prevent that.
/ Linoleum garage floor #6
I would be concerned that linoleum might become to slippery when it got wet or had a bit of oil or hydraulic oil spilled on it. Not a good condition for a work area. At least with most paints you can add silica sand to eliminate that problem.
/ Linoleum garage floor #7
I looked into various products designed for garage use. They usually involve no adhesives just snap together. They are pricey but look good.
A google search for "garage floor tiles" should give you plenty of information.
/ Linoleum garage floor #8
Miltrade, Another product is called racedeck which is the snap together a previous poster mentioned , I'm sure there are other manufactures also sears is rumored to have a garage tile for the more budget conscious consumer , might be worth a look ... /forums/images/graemlins/smirk.gif
If thats not for you ,my personal want would be epoxy with the non-slip additive (play sand) and speckles for a more textured look... /forums/images/graemlins/cool.gif
Thanks for all the input. When I said that I had tried garage floor paints, they were not on this particular floor. I tried them on my previous floor and they all came up, no matter how closely I followed the recommended application, use of primer, etc. etc. This floor has not been painted. I have some of the interlocking rubber matting in my barn (weighs about 75 lbs each piece), but I have been hesitant to transport it to the house.
The garage is to be used for parking only, no jackstands, no work area etc.
I just thought that maybe an easy solution would be to put down some black linoleum tile squares as they can really have a showroom quality if kept clean.
But I'll consider all the downsides and make a decision.
/ Linoleum garage floor #10
I'm going to bet your not looking at linoleum tiles. I can't think of the name but, it is a solid material that used to be asbestus(sp) based. There about $.59 each and just glue down. linoleum has a very thin top layer that is easy to break through.
What don't you like about concrete? Is the finish rough? Mine is so smooth I have to be carefull when wet. She cleans as if it were in the house.
/ Linoleum garage floor #11
I looked at the Racedeck and similar stuff, and for the price they want, you could put down a marble, slate, granite or porcelain tile floor! (assuming DIY on the labor). I think the Racedeck stuff was like $5 per sq-ft and you can find granite, marble, slate, or porcelain tile sometimes under $2 per sq-ft (plus maybe another $0.50 for thin-set and grout).
The other flooring I was looking at would be an epoxy or cement-based terazzo, but I have not found any DIY systems for that or pricing.
Another idea would be to put a top-coat of thin self-leveling cement which could be dyed to any color.
Another idea would be to chemically stain the surface of the concrete to a nicer color.
If I was to do my garage floors over again, I would have just poured them with color-dyed concrete to start with.
- Rick
/ Linoleum garage floor #12
There are products out there that are very good floor coatings. "Paint" is not one of them. So much crap has been put out there, epoxies ect. most people have lumped everything together as "paint" I am doing my garage floor this spring- time permitting, and I am using a blend of DCPD & Isothalic polyester resin, filled with playsand. This will be catalyzied at about 2.5 % with MEK-9. I will apply it over lightly scarrified concrete sweeped and blown clean. I might even throw some grey tinit in it or leave it a natural dark amber. I will pull my toys in the next day and have a almost bullet proof floor for less than a $1.00 a square that is easy to clean and will touch up if need be. Oh ya- I think the tile is great idea if you are super clean and don't get any moisture- I am just way to big of a slob to use tile-
/ Linoleum garage floor #13
Have a neighbor that wouldn't drive on his new concrete in his garage until he painted it first with epoxy containing ground up rubber for traction. He swore the stuff would hold up for years. Within the 1st 6 months it was already flaking off the floor. It now looks like the devil and is going to take a lot of labor to get the rest cleaned off the concrete.
/ Linoleum garage floor #14
<font color="blue"> If I was to do my garage floors over again, I would have just poured them with color-dyed concrete to start with.
- Rick </font>
GOOD IDEA
My policy is never paint concrete or brick it prevents all of the hassles discussed in this thread.
MY FIRST CAR http://chevy.tocmp.com/chevyscrapbook/files/kamp50.jpg
/ Linoleum garage floor #15
Like you I am thinking of putting down tile in my garage. I know my response is not right on point but my experience might help. If I did it I would use the same material I used in the house to cover 700 square feet of concrete floor - commercial grade Armstrong vinyl composition tile glued down with Armstrong Premium Floor Tile Adhesive S-750. This glue is supposed to be moisture and alkali resistant. That is as opposed to other glue sold by Armstorng that is not moisture reistant. (purchsed these materials at Homechepo). Cool tile colors are available - Armstong has a good web site. For those few areas where the floor was not flat, that I did not want to fix, I used a torch to gently so to speak heat the tile up as I laid it to make it conform to the floor (In one area I used a jack hammer and floor leveler instead to level the floor). The floor must be waxed two or three times with other Armstong products to give it a gleam and protect it. So far I have had a few slightly loose tiles but nothing unacceptable. The tiles I put down are in my family room, spare bed room, bathroom and in the basement laundry room (12X12). So far I am very happy. Tiles I put in are right at the entrance to the garage and get fair degree of traffic have hled up well. To me I look for value - tiles cost me as I recall 4 years ago .56 each. Glue was I think about $34 per 1 gallon container. They are composite - color all the way through. As I recall 1/8" thick. Yup, they can break after you install them if you have surface imperfections under them. A pebble under a tile will eventually push up a small are of tile and can cause a tiny crack. These tiles are used in schools and other very high traffic areas. Yea I wonder how they would hold up in my garage here in Connecticut under my tractor and car as snow melts and the water gets in the seams between tiles. Or after the car is out in the rain. I also wonder about tire scuffs and oil - but how do the alternative floor coverings handle this? Break or damage a tile - pull it up and replace it .56 (now might be up to .67) plus glue and time. But gewiz .56-.67 a square foot, plus glue and trowels? I have looked at other surface treatments or tiles and the cost to me is really high even epoxy aint cheap - heck for what I have seen you could almost put down grade B hardwood floors (just kidding) for the same cost. Looks to me like some of the local car dealers have this tile in their show rooms too. Finally, even a desk jocky like me can put this tile down. So your idea has real merit from my view and I very well might do this soon myself.
/ Linoleum garage floor #16
Miltrade , I think you are meaning something like this guys floor scroll down ...(dial-up forget it) /forums/images/graemlins/frown.gif
Vinyl tiles or VCT??
Not a bad idea for parking but can possibly present a problem with lifting if too much moisture is allowed to stand or oil ,antifreeze or other fluids get between cracks... A possible solution might be to seal it with a ureothane or other sealer designed for such applications, But you would have to ask someone with a better knowledge base on this matter... /forums/images/graemlins/blush.gif
/ Linoleum garage floor #17
Nasty135, that guys floor in the link you provided is EXACTLY the stuff I was thinking about using. Not the soft, highly laminated, household linoleum tiles, but the more durable kind that you would find in govt buildings etc. Looks like he did the same thing. I think I might just try it. If, after use, any of the tiles lift or crack, will only cost me a few bucks to replace a few here or there.
/ Linoleum garage floor #19
</font><font color="blue" class="small">( any of the tiles lift or crack, will only cost me a few bucks to replace a few here or there. )</font> <font color="blue"> </font>
EXACTLY, BTW garage junkies.net is where I got the link to those pics as the previous poster reccomended... /forums/images/graemlins/wink.gif
I'm an Old gearhead so I like that site also, But not as much as this site /forums/images/graemlins/laugh.gif
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
2011 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64556)
2011 Chevrolet...
John Deere 1770NT Planter Drive (A65640)
John Deere 1770NT...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
Concrete Mixer (A62613)
Concrete Mixer...
GYRO TRAG GT-25 FORESTRY MULCHER (A65053)
GYRO TRAG GT-25...
