Linked pedal operation video
   / Linked pedal operation video #1
CMV
Platinum Member
NC
Kioti NX4510HST (previous LS XJ2025H, JD 500C)
KIOTI NX4510 HST Linked Pedal - YouTube
Just a short video showing my new machine going over some rough terrain to see how much better the ride would be and a demonstration of the HST with linked pedal in operation. :)
   / Linked pedal operation video #2
I've found with mine if I'm doing a lot of loader work I run the hand throttle up around 1500 RPM. Because backing up is too slow otherwise. Mowing a large pasture is much easier with the cruise control also.
   / Linked pedal operation video #3
Without the linked pedal and with my non Tier 4 motor I am inclined and encouraged to run at above 2000 rpm for most activities other than PTO related in order to keep the engine running clean. In fact I find 2200 rpm to be a nice sweet spot for the 2610 if your choosing a loader activity setting and not having Linked pedals. Then of course the Hydro does all that increase in forward or reverse activity by the touch of the pedal. Maybe not as fuel efficient but good for the motor. The dealer strongly recommends operation at or above 2000 rpm. Diesels need to run hot and work at those rpm's to keep them clean. It will lengthen your time between regen and on a non regenerated motor keep them cleaner reportedly.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
197390 (A50459)
197390 (A50459)
2024 New Holland T8.410 MFWD Tractor (A52128)
2024 New Holland...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2018 CATERPILLAR 259D SKID STEER (A51242)
2018 CATERPILLAR...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
