Link to my homebuilt tractor story
   / Link to my homebuilt tractor story #1
roygage
kubota L3000DT
Twenty some years ago I built a small, 2800 pound, homebuilt tractor. The unique part about it is the use of a front wheel drive engine and trans-axle turned 90 degrees which uses only one of the original drive axles to shoot forward where it engages a transfer case from a 84 Nissan 4x4 then uses another drive shaft pointed rearward to feed the nine inch ford rear end which hangs on a pair of semi truck tires.
A link to a writeup in my blog. Will be trying to get some good pictures to go with it when I can.
Life on Highway 9
   / Link to my homebuilt tractor story #2
I like the cherry picker roll bar combo!
An updated link which will bring you to the correct page, the original brings you to the blog but then you have to search the blog to find the story. Life on Highway 9
   / Link to my homebuilt tractor story #4
Nice build! I can't imagine it would be that hard to add a 3 pt lift to something like that.
It does have one, center link and two arms. The lift is provided by a chain to the cherry picker. Only about ten inches of lift but worked well to lift my old three point mower. Couple of other tractors with three point at our place so no longer much need of it. But yes, if one wanted it could be improved upon. At this time tractor is pretty much just used for pushing, pulling, spraying and fun.
2018 LEDWELL LW48HT2-10 PB-LP (A52472)
2018 LEDWELL...
7ft Adjustable Scrape Blade (A51573)
7ft Adjustable...
2014 Chevrolet Cruze Sedan (A51694)
2014 Chevrolet...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2007 WESTERN STAR 4900 (A52472)
2007 WESTERN STAR...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
