Link belt to replace fan belt?
   / Link belt to replace fan belt? #1
Turfmaster6
Greenfield, MA
Craftsman 1100, MF GC2310
Greetings,
Would be surprised to discover this hasn't been discussed many times but I can't figure out how to entire the search tool to find precisely the phrase I'm seeking... to the main question...
The fan belt on my GC2400 needs to be swapped out. I'm not up to dealing with the insane design decision to loop the belt around the drive shaft with my antique body, and would like to just cut it off and drop in a linked belt. I know linked belts from machine tools but have no experience with them in the fan belt role. Has anyone done this and if so, how did it work out for you? Thanks in advance.
T
   / Link belt to replace fan belt? #2
I had a thread a while back discussing the same idea. I ended up following through with the idea. I’ve only used the machine to mow twice since then which is 3-4 hours total run time and so far so good.
   / Link belt to replace fan belt? #3
My dozer has a hydraulic pump mounted to the front engine pulley. When the belt broke I put a link belt on it otherwise I would of had to remove the pump. That was at least 10 years ago. It's worked just fine.
Thanks folks.. think I'll give it a try.
T
Anyone got a quick answer to this second part of the change over? I can find no information online about the belt parameters for a Massey GC2400 fan belt... only a part number for it. Does anyone know the belt length and perhaps the "inner and outer" widths or however the v-aspect of the belt is spec'd... so I can match get a link belt that's in the ball park. Thanks in advance.
T
   / Link belt to replace fan belt? #6
Link belts come in the same widths as standard v-belts. A-4L, B, etc.. if the wide part of your fan belt is 1/2" then it's an A-4L, if it's 5/8" then it's a B. Link belt is sold by the foot and you make up your belt length by adding or subtracting links until you get it right.
Fenner Drives makes the best Power Twist belt in my opinion but it's about $12 a foot. Harbor Freight sells a knock off that's green in color and works fine...I use it on my drill press in the shop. I sprang for the Fenner Power Twist for my triple wide belt drive on the table saw....smooth as silk.
LOVE talking with people who know things:) Thank you very much M.
T
43013 (A51691)
43013 (A51691)
2017 Hitachi ZX245USLC-6 (A47384)
2017 Hitachi...
1989 Cat 953 Crawler Loader (RUNS) (A50774)
1989 Cat 953...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
Land Honor Quick Attach Bale Spear (A50515)
Land Honor Quick...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A52748)
John Deere 5090E...
