Disc Harrow Linebach 240 Question
/ Linebach 240 Question #1
Mitkof
Cathlamet, WA
New Holland Workmaster 40
Just got a good used Linebach Model 240 disc harrow.
Need source for Linebach manuals.
Or source for information on cleaning and lubing the bearings.
Thx any help appreciated.
/ Linebach 240 Question #3
They went under year or 2 ago. Mostly commodity parts though. Discs & bearings should readily avaliable from your local ag parts dealer or online.
Thx Steave, Excellent link to the Linebach 240 manual, I really appreciate it.
/ Linebach 240 Question #6
I've bought several Leinbach attachments from the EA company over the past several years. Maybe they can also help/advise you of what you need.
/ Linebach 240 Question #7
All of the Leinbach domains are owned by EA... I think EA essentially purchased their assets. There's another thread on TBN about it, IIRC, that comes to mind.
/ Linebach 240 Question #8
I have a Leinbach PHD. Called em looking for a downpressure kit a year or so ago... was a week or 2 late as they were going under.
ETA sold a lot of Leinbach stuff as others noted & might be able to help.
Most of their stuff was commodity parts mounted to frames they built, which makes replacement parts easy despite them being gone.
Thanks Guys,
Everything Attachments helped me out. Charles George works for EA after 40 years at Leinbach. Here’s my note to him…
I finally got that [new to me] used Leinbach 240 into my shop, 3 gangs where very stiff, one gang was frozen. They are 3-hole bearings you said no grease require [that’s really good info thanks].
I WD-40’ed all 8 bearing pulled out bale twine wrapped on one and barbed wire wrapped on another. Spun the three hard ones and forced that frozen one. After 15 rotations they stared to loosen. More WD-40 and spun them the opposite direction. Let sit for 20 minutes… YAHOO…
All 4 gangs now spin super free and all bearing feel good and tight.
Any other Leinbach secrets about the 240 I should know???
Thanks again for your help… Tell Everything Attachments they should built that 240 as it looks bullet-proof and farmer fixable [a real plus].
Stay safe in the Matthew Storm…
Hi Fallon, PhD,
Got a brain test for you. What color Red are the Leinbach attachments???
Maybe XO-Rust Tractor Red? or Rust-Oleum International Harvester Red? or their Regal Red?
I need to repaint and would like to match if possible.
Many thanks...
/ Linebach 240 Question #11
My PHD & the other PHD boom I picked up were yellow. Something close to the yellow you see on any construction equipment. Think I used Cat yellow when I rebuilt my PHD (redesigned it to fit on a QH & added brackets to add hundred lbs ontop)
Thanks, sounds like Leinbach used many colors.
I was hoping they just use a single red... like International Harvester Red, but no luck.
I looked today and there are at least 3 Tractor red colors used... now I just need to find the one Leinbach used.
Have a great week...
(2) New 14-17.5 NHS tires w/ fluid on 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
Ford Truck Tire and Rim (A65640)
Ford Truck Tire...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
3pt Counter Weight (A64127)
3pt Counter Weight...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2016 JCB 507-42 (A64126)
2016 JCB 507-42...
