Lincoln AC/DC welder
   / Lincoln AC/DC welder #11
i would rather have a miller thunderbolt.the lincoln has tapped settings the miller has infinite .
   / Lincoln AC/DC welder #12
handirifle said:
As for portability, I already have a 110v, 90 amp mig that I use mostly flux wire in, and it has done a yoemans duty for me, but I occasionally need more amperage, like my upcoming trailer axle replacement, where I need to weld the spring hanger tabs onto the frame. I may just have to do it with mine in several passes. But someday I would like to build items like a log splitter, and I doubt the little mig will penetrate deep enough to hold the wedge against a 30 ton ram. I do not get a good mental picture when I see the wedge go flying.......
Most if not all my welding, is done in my shop, where the mig plugs into a dedicated 20 amp circuit, and any new machine will have it's own 110/220 circuit of what ever amperage is needed, so that won't be a problem. My workshop is 24x30 so anything I plan on making will easily fit inside.
My preference is for a machine of at least 160 amps, maybe more, just to keep the duty time up.
HF has some 225 amp machines, that I THINK are inverter machines, but can't see that in the specs. They have a low duty cycle (20%) but that's at top amps and I doubt I'd ever need that. I cannot ever see me welding anything that needs that much power, or honestly, me even knowing that I DID need it. :)
Check out the Everlasting stick welders. They have a good reputation here and you can get a 200 amp stick welder (PoweArc200) for $350.
   / Lincoln AC/DC welder #13
k0ua said:
Or look at this little 140 amp rig that will run on dual voltage up to 85 amp with 3/32 electrodes on 120 volts or 140 amps with 1/8 inch electrodes on 240 volts. and comes complete with a 17v TIG torch for scratch start TIG all for $275.
I think there is some kinda of TBN discount if you contact Mark here on this forum
PowerArc 140ST - Multi Purpose Units, Diesel Generators, Welders, Arc Tig Mig Welding Equipment, Plasma Cutters
James K0UA
I have the pa 140 and it has worked faultless for the last 7 mo. Like Mr Koua said its as light as a lunch box and not much bigger. It has been my go to welder since I got it and about 120 lbs lighter than my ac welder.
Well I will certainly look into them, I need to make some changes to come up with the $$$. I have an AR receiver that I need to sell. That will free up enough money to be a little more picky. I need to balance cost with frequency of use. For most jobs the little MIG is hard to beat.
   / Lincoln AC/DC welder #15
I would be more than happy to swap you a Lincoln AC225 tombstone in great shape with a Hand cart to move it. with 25 foot leads for that AR lower. Can you come to Branson?
James K0UA
You know, we are heading east the 13th, to Huntsville, Al, with a number of stops along the way. Unfortunately, the little Honda would croak with that in the trunk. Otherwise it would be a done deal.
   / Lincoln AC/DC welder #17
Well the offer stands if you can figure some way to get it.. Shipping would be prohibitive I am afraid. It probably weighs 100 lbs or more. the leads alone are probably worth an extra 75 bucks. the harbor freight hand cart is 25.
James K0UA
   / Lincoln AC/DC welder #18
I had - literally - never welded (excluding oxycetelene) before 4 months ago. I did some 'net research and talked to guys in-person that have plenty of experience.
I agree do NOT buy a NEW stick. I paid $250 for an AC/DC Tombstone. I figure if I learn it decent, I may want to get a MIG or a TIG down the road. Then I can get what I want without compromising to include stick.
Or, if casholla is no object, Hobart has for around $3k an 11kw generator/welder that I believe is capable of ALL processes and has a 100% duty cycle
edit - Oh, I also bought the two stick welding DVDs from Northern Tool. Great for beginners like I. I would probably buy the DVDs on MIG and TIG before getting serious on purchasing one or the other.
Well money is a HUGE factor, that is why I am looking at Harbor Freight welders also. I have not ruled out the PowerArc's I just have to weigh all the factors of my needs vs funds.
   / Lincoln AC/DC welder #20
Handirifle... I noticed you're on the Central Coast. I am too for most of the year. N/W Atascadero. Where are you located? I'm about to purchase an Everlast from Mark Lugo too, the PA 300.
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A55851)
2015 Toro Multi...
1990 John Deere 2955 Cab Tractor (A55218)
1990 John Deere...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2017 HAMM H10i SMOOTH DRUM ROLLER (A52706)
2017 HAMM H10i...
Informational Lot - Financing (A55301)
Informational Lot...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
