Limp Bucket
/ Limp Bucket #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
I know this has been covered before but the thread search is not working to well for me. What is the cause of a slightly rubbery bucket. Never really noticed it much but as the BX is getting older, its getting a bit worse.
/ Limp Bucket #2
Matt, you could clamp and weld some flat steel to your bucket to strengthen it and make sure you clamp the bucket real solid and true it up/square it nice and tack your welds before you do a full weld so you won't get warpage in bucket
Jim
/ Limp Bucket #4
Do you mean like your cylinder ends are wallowed out/egg shaped or something like that?
Some times the pins or bushings can be replaced or the whole cylinder end with new pins and bushings
Jim
/ Limp Bucket
The bucket just seems to not stay in position with weight in it. Its like the hydraulics are not holding it in position. The pins and all look good. The BH makes some noises that are bit odd too, but I think that is just metal making sounds.
/ Limp Bucket #6
Is your hydraulic fluid up where it belongs and do you have any leaks? Those would cause that
Jim
/ Limp Bucket #7
Sounds like you have air in your hydraulic cylinders. Just extend and contract both your tilt and lift cylinders to the max holding for a few seconds and the excess air will be eliminated.
OrangeGuy
/ Limp Bucket #8
If you have the tractor full of fluid to the correct level, and you extended and retracted the cylinders a few times and it still sags when loaded. THEN you probably have leakage past the cylinder seals. That can be fixed pretty easily with new packing. Any hydraulic shop or the Kubota dealer. I do them myself and save the money. It's really pretty easy.
jb
/ Limp Bucket #9
Our B2910 has done this since shortly after it was brand new. I mostly notice it when transporting and I have a packed/heaped bucket of heavy material - usually wet soil or sand. Could it be that the relief valve is just passing a little fluid from shock loads ?
/ Limp Bucket #10
No.
The relief valve is on the other side of the control valve.
/ Limp Bucket #11
It is likely an internal leak in the loader control valve. The oil gradually leaks past the spool and the bucket moves down on its own.
Willmar and AgChem Parts and Service Manuals (A63117)
Willmar and AgChem...
2005 CLUB CAR CARRYALL UTV (A64280)
2005 CLUB CAR...
Kubota L3901HST
Kubota L3901HST
2019 Ford F-150XL (A64119)
2019 Ford F-150XL...
(5) Drive Motors (A64119)
(5) Drive Motors...
1998 PETERBILT 378 FLAT TOP DAYCAB ROAD TRACTOR (A64280)
1998 PETERBILT 378...
