Limits on reverse speed
/ Limits on reverse speed #41
Farmall140 said:
Barry, I also changed to Mobil 1 on the first oil change. Now at 250 hours and no leaks other than a filter I did not get tight enough 1 time. I also practice a little overkill and change out the Mobil 1 every 50 hours...I think I could probably go longer with the Mobil 1 oil but it's not that expensive....YET!
Over kill is good, I do the same thing. ;)
/ Limits on reverse speed #42
I change the Mobil 1 and oil filter evey 50 hours as well.
/ Limits on reverse speed #43
Are you saying that a quart of Mobil 1 is not expensive? $5.95 may not be expensive to you, but that is about 4 times more than dino oil. If you were to put that Mobile 1 in the hydraulic system, you would get a shock. That would be $94.00 to replace the dino oil. Now Mobile 1 at $5.95 a qt times 80 quarts, [ 20 gal ] = $470.00 This is relative to a PT-1445, and larger units.
/ Limits on reverse speed #44
No J.J. I didn't say that. Only agreeing with Farmall140 and Bob, that changing out the engine oil every 50 hours is a good thing to help protect your investment.
I can, afford a few quarts of engine oil even at 5.95 a bottle every 50 hours. Now when you’re talking about the hydraulic tank, that's a whole other animal. :)
/ Limits on reverse speed #45
The 22 HP engine is only a little over a quart of oil. I did changed the hydraulic oil to Mobil 1 and yeah that was expensive.
/ Limits on reverse speed #46
OK,
To me $500 may or may not be important. What is more important to me is... how much do i worry about it??? If $500 per year protects my $20-25K investment (real or imagined), is it worth it???
$500 per year -- kids don't eat. NO, NOT WORTH IT!!!
$500 per year -- $500 Ishouldn'thavewastedthatmoneybutI'mnotreally missingit. I'M PROBABLY OK WITH IT
I guess it really depends on what's going on. Hobby vs Livelyhood.
/ Limits on reverse speed #47
IrTxRx said:
OK,
You don't have to change transmission fluid but every 5 years or so. The 422 has a 10 gallon reservoir -$238. Not so bad. If it were $500 a year, no way.
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
BOBCAT T190 (A60736)
2011 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2011 HEIL TRAILER...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
John Deere 568 Megawide Plus Round Hay Baler (A60462)
John Deere 568...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
