limited RPM at cold start, is this normal?
   / limited RPM at cold start, is this normal? #21
They replaced the fuel filter today and said it was pretty bad. Dunno know how all the contaminants got past the fuel screen. I kinda think it's from the factory, but who knows. I hope this was the fix, and I hope this post helps anyone else with this problem in the future.
   / limited RPM at cold start, is this normal? #22
Huh, my g3038 starts rough, but not that rough. Then again, hasnt been run below about 50 degrees yet.
   / limited RPM at cold start, is this normal? #23
Did the service fix your problem? just wondering.
   / limited RPM at cold start, is this normal? #24
Yup! Runs great now.
   / limited RPM at cold start, is this normal? #25
how many hours when you changed the fuel filter?
   / limited RPM at cold start, is this normal? #26
Only had 40 hours on it.
   / limited RPM at cold start, is this normal? #27
Just had mine serviced under warranty due to the rough start. It's interesting because I have a '91 John Deere 770 that starts right up in sub-zero weather and I rarely even use the glow plugs. This 2014 G3038 starts hard in 50 degree weather, even after the glow plugs cycle (I always wait for the cycle to complete). Perhaps some of the difference is due to engine design (JD is direct injection and this is indirect injection), but any modern diesel should start without 60 seconds of low, rough, galloping, smoking idle. Anyway, it's on the way home now from the dealer. The Dealer's service guy was great and he agreed that it did not start right, but he wasn't sure what was wrong with it and the LS rep that he talked to had no good ideas. He said that he tried and some of the other G3038s on the lot didn't start well either (wish I had known about this problem when I bought). Based on this thread, I asked the service guy to replace the fuel filter (28 hours on the tractor) and he did so under warranty. He thought that MIGHT have helped, but he wasn't sure. Other things that he checked were to make sure that the glow plugs were energizing and the timing of the fuel injector. LS rep advised him to tell me to run it to 50-100 hours to see if that fixes the problem and to remind me that there was a 5 year warranty if that doesn't fix it. Basically, they said it probably just needs to break in. Fair enough, I'll try it and we'll see. Presumably, LS will stand behind the warranty if the problem does not resolve.
   / limited RPM at cold start, is this normal? #28
How is your G3038 starting now - mine looks like a mosquito sprayer on first start, regardless of the temps. Smooths out after about 20 seconds but before that, wow! Only 17 hours on the machine.
The outside temp when this video was shot was 60f.
   / limited RPM at cold start, is this normal? #29
Do you have the Mitsubishi engine? I have the 41hp Mitsubishi and mine starts easily with 2 cycles of the glow plugs @ 0 - 10* F. With very little smoke. Maybe you should check to see if your Glow-Plugs are working properly. Just a thought. :)
   / limited RPM at cold start, is this normal? #30
Mine has been acting up again, but it's so cold outside here in upstate ny. Its been 10 to 20 degrees below freezing and she putters for about 45 seconds before running. The more I heat the glow plugs the better it starts. Even so with about 3 or 4 glow plug cycles it's still rough.
I picked up a engine block heater from the dealer. I'm hoping it's just cranky cause of the cold. A few weeks ago I did the 50 hour service and the fuel filter was nice and clean (it was replaced a few hours ago) so Im pretty sure it's not that again.
I'll update once shes got the heater in her.
Mini Skid-Steer Grapple Bucket (New/Unused) (A59225)
Mini Skid-Steer...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
DIGGER DERRRICK (A55973)
DIGGER DERRRICK...
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
