Limited Cat 1
   / Limited Cat 1 #1
777777
Ontario Canada
Jinma 204 -- now gone
Hi All,
Ok, through the resources on this board, I have been able to research PTO and its variances.
Now when you look at tractors, I see Cat 0, Cat 1, etc.
Can anyone explain a limited Cat 1 ? Is if between a Cat 0 and a Cat 1 ?
Basically, what is a " limited Cat 1"
Thanks for any input.
Tom /forums/images/graemlins/confused.gif
   / Limited Cat 1 #2
Here is a thread that should get you started on the answer. Click Here
I did a search for Limited Cat 1 using the search feature at top of page. Got quite a few hits.
   / Limited Cat 1
Hi,
Thanks for the push in the right direction.
So basically, as I understand it, a limited Cat 1 is basically a matter of the arms not going out as far as a Cat 1 and you are limited in lift height because of the tractor size itself.
Does this mean that all sub compacts are Limited Cat 1 ?
And all compacts are full cat 1's ?
Thanks a bunch. Has been really helpful.
Tom
   / Limited Cat 1 #4
<font color="blue"> Does this mean that all sub compacts are Limited Cat 1 ?
</font>
Yes and no. Each manufacture has their own spec's. You will have to look at size when you are out shopping.
   / Limited Cat 1
Hi Ron,
Thanks for the help.
Nothing is easy is it.
However I do now have a bit better understanding and know a little better what to look for.
Thanks again and have a good one.
Tom
John Dozer JD650 (A53421)
John Dozer JD650...
2019 John Deere 3025E (A50123)
2019 John Deere...
48" Skid Steer Pallet Forks  (A52384)
48" Skid Steer...
CABINET (A53843)
CABINET (A53843)
2021 Bobcat S740 (A50123)
2021 Bobcat S740...
CAT 5000 IB Diesel 2PD5000 (A53421)
CAT 5000 IB Diesel...
