LIME SPREADER FOR FOOD PLOTS
   / LIME SPREADER FOR FOOD PLOTS #11
Here's an idea. Take a look at the Ferguson "Yardmaker" seeder/spreader. A cousin of mine bought one last spring. I've used it a couple times to spread fertilizer. It's essentially a drop spreader that's driven by a spike-tooth roller/aerifier that's mounted behind the seeder portion. They come in 4', 5', 6', 7', and 8' widths, both pull-type and 3-point. John bought his at Sweet Equipment, who advertises here on TBN. The one I used is a 7', 3-point model. It spreads lime, fertilizer, and grass seed (or any small seed I guess) It would be excellent for seeding food plots as well as spreading lime. The drop spreader part is very much like the old E-Z Flow spreaders in the way it works.
Spreader can be pulled by tractor or ATV. Very solid construction. Big tires roll easily, even on rough ground. Although I don't know how to post a link to their website, if you Google "GROUNDBUSTER", it will get you there. Good luck
   / LIME SPREADER FOR FOOD PLOTS #13
Is this it? Ground Buster page
If so this is a lot like the E-Z Flow spreaders that I was talking about.
   / LIME SPREADER FOR FOOD PLOTS #14
Looks like a nice spreader but for $2100 I would need to spread a lot of lime to make up the difference between lime cost. Thanks for the info though, I would like a spreader that would work pulverized lime.
MarkV
   / LIME SPREADER FOR FOOD PLOTS #15
Look for an old E-Z Flow. You should be able to buy one for $100 in good shape. If you find one at an auction it might go cheaper.
With the difference between the cost of pulverized and pelletized lime in our area being over $1 a 50 lb bag, it will take us about 50 tons to recoup the cost of the spreader. At the rate we are establishing plots, that should take about 4 years or so. And that doesn't count the cost of a broadcast spreader. I wish I had been able to locate the used equipment that seems to be available everywhere but northeast Pa. I could have saved enough to buy a used tractor.
Robert in New York, thanks for the picture that I could not come up with. Some of the guys in my camp are thinking of hiring out the spreader to neighboring hunting clubs that are putting in food plots. Since the local Agway wanted $ 1200 to spread 4 tons for us, we should be able to pay it off a lot sooner.
   / LIME SPREADER FOR FOOD PLOTS #18
Here is a pic of a drop spreader that I used last summer to spread 35 ton on 10 acres. There are still a few around for a reasonable price at auctions and farm sales. Although I used my tractor last year I have spread lime with this spreader with my Honda 300 4 wheeler in the past.
   / LIME SPREADER FOR FOOD PLOTS #19
If you were in North West PA you would have found a lot of the EZ flow spreaders near Lake Erie. You just chose the wrong side of PA to live /forums/images/graemlins/grin.gif
It happens to all of us, when you really want something you can't find what you want for the price you want. After you pay top dollar for a new unit you find them all over the place for a lot less.
As for renting the machine out, just remember, other people don't always treat equipment well. They don't own it and have no incentive to be careful. We only let trusted friends use any of our equipment. Others we will run our equipment for them and help them that way. Good luck though no matter which way you go.
2008 Isuzu NPR-HD Landscape Dump Truck (A55788)
2008 Isuzu NPR-HD...
BOBCAT 18PLA SKID STEER HYD COLD PLANER (A54756)
BOBCAT 18PLA SKID...
2011 Ford Ranger Ext. Cab Pickup Truck (A54814)
2011 Ford Ranger...
2015 KENWORTH T270 SERVICE TRUCK (A51406)
2015 KENWORTH T270...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump (A55787)
2025 60 Gallon...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
