Spreader lime/fertilizer spreader questions
   / lime/fertilizer spreader questions #11
Maybe your spreader does not have an agitator inside the hopper ? The spreaders I have seen work are red cone spreaders with 750 lb capacity and I think the brand was cosmo?
   / lime/fertilizer spreader questions #12
I've used the little hand spreaders to spread dusty lime. However, the granular is better. That's what I'd get for a big spreader. It'll take the lime almost a year to work its way into the soil anyway, granular or dust.
Ralph
   / lime/fertilizer spreader questions #13
</font><font color="blue" class="small">( Maybe your spreader does not have an agitator inside the hopper ? )</font>
Maybe Teddy's doesn't, but mine (a Caroni, I think) has a removeable agitator. The first time I tried it with crushed lime, I removed it - haven't used it since. The agitator compressed the lime at the bottom of the funnel - the last foot or so - to a consistency where nothing would come out. I had to dump the lime out on the ground, and basically chip the agitator out.
And yes, the lime was dry - the spreader was dry - the day was dry. That's the point at which I went to granular lime, and never looked back. It costs about $30/tn more, a difference I consider worthwhile just to avoid the aggravation of a bunged-up spreader.
Don't get me wrong, there might be better agitator designs out there. In my case I had to find out the hard way, that I bought one that was apparently not designed with crushed/powdered lime in mind.
//greg//
   / lime/fertilizer spreader questions #14
Man, sounds like a pain. I also use granular,but he asked about powder , and I have seen it done without any trouble, must be the exception to the rule?
   / lime/fertilizer spreader questions #15
I have a small manual push spreader, a garden tractor sized one, and a 500 lb. 3pt PTO spreader. The lime pellets work fine in all of them. Also, way less dust than the crushed lime powder!
   / lime/fertilizer spreader questions #16
The powdered ag lime is cheaper.. but doesn't broadcast very far.. peletized lime speads nice.. but cost more.. etc.
That dusty lime runs pretty good thru a drop spreader though...
Soundguy
   / lime/fertilizer spreader questions #17
I talked to co-op today about lime. They will come out to my place and spread ag lime for 19 bucks a ton. The 50 lb bags of pellets run 5 bucks a bag (200 dollars a ton) I pick-up, haul, and spread. Ummmmm........I think I know which route I'm taking!
Also, someone mentioned that both will take about a year to change soil pH. I don't think thats true. I've always read that pellitized lime will effect the pH MUCH faster than ag lime. Because of the fast breakdown I believe the max application rate for pellets is 50lb/1,000 sq ft. If you're soil test calls for more you should apply in two applications sepatated by approx 6 months.
   / lime/fertilizer spreader questions #18
</font><font color="blue" class="small">( Also, someone mentioned that both will take about a year to change soil pH. I don't think thats true. I've always read that pellitized lime will effect the pH MUCH faster than ag lime. Because of the fast breakdown I believe the max application rate for pellets is 50lb/1,000 sq ft. If you're soil test calls for more you should apply in two applications sepatated by approx 6 months. )</font>
I was told the same thing by my local supplier, but if you google on 'pettitized lime' you will find reports from numerous universities that are similar to this quote from the UKy Extension Service
"Contrary to popular belief, the speed of reaction of pelletized lime is no faster than that of bulk ag lime. "
   / lime/fertilizer spreader questions #19
Hydrated lime or often called burnt lime works immediately when applied to the soil. Pelletized lime and agricultural line needs 6 months to one year before the lime starts to react in the soil. It often takes 2 years for agricultural lime to realize its full benefit in the soil.
CCM fertilizer spreaders available in 3 sizes from sub-compact to utility tractors. Prices Start at $275
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
2019 Genie GS-3232 32ft Electric Scissor Lift (A53421)
2019 Genie GS-3232...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52707)
2017 CASE IH 580...
2014 COMPTANK ACID TRANSPORT TRAILER (A55745)
2014 COMPTANK ACID...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
