Snow Attachments Lights on snow blower
   / Lights on snow blower #1
Jerome
Elmvale Ontario Canada
Kubota L245dt
I was thinking of mounting lights on the top of my snow blower because with the light on top of my cab all I really see is really well lit snow dust blown out of the chute. I was thinking that with the lights on blower they would be past and below this snow and I would be better able to see. Has any done this?? I know that I would have to run a ground to the blower is there any other problems?
thanks
Jerome
   / Lights on snow blower #2
If there is a lot of vibration, the bulb filiment won't probably last long. Try a rubber cased tractor lamp or some kind of rubber mount.
   / Lights on snow blower #3
From my experience with front mounts, 48" & 63", the blowby is worse at the machine than back at the cab. Between the vibration or the light becoming encased in ice i dont think you will gain anything, in fact the reflection off snow out there could work against you like highbeams driving a car in a blizzaer. JMHO.
   / Lights on snow blower #4
I have done this and it works great as I perfer to move snow early before daylight. Used a heavy duty light w/o any vibration issues. Enables me to do a better job of cleaning up the drive. I also have lights mounted above the B2410 rollbar-makes a great combination.
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A50323)
2007 Kenworth T800...
Ditchwitch 1030 Walk Behind Trencher (A50121)
Ditchwitch 1030...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A52748)
2012 KINZE FLAT...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2006 Dodge Ram 3500 4x4 Pickup Truck (Diesel), VIN # 3D7LX38C36G220767 (A51572)
2006 Dodge Ram...
2005 Mack Vision Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Mack Vision...
