Lights on NH TC24D
   / Lights on NH TC24D
A shot from the back showing both lights and the "natural" curve the wiring takes which allows me to fold the ROPS w/o any trouble.
Here you can see the wiring come back up from under the tool box to go under the plastic cover on the fender to go to the switches as well as the ground wire connected under the seat.
After almost a year of using the lights in this configuration I thought I would post an update about my lack-of-happiness. /forums/images/graemlins/frown.gif I still wasn't real happy with the quality of light I was getting out front. It seems my head was also always in the way. Another problem I figured out while I was doing the upgrade, I had forgotten to turn the lens back upright since I had the light mounted upside down. /forums/images/graemlins/mad.gif By the time I realized this, I was already half way through the process and decided to continue. A couple of weeks ago I had run the wiring to add a relay. I knew I had to do this for 2 reasons. The switch I had used wouldn't carry 2 55 lights, the other reason is the factory fuse I was only is only 10A. It couldn't carry the 2 fronts + the rear work light. I forgot to get a picture of where I mounted the relay, but it is under same cover that I put the switches under. It ended up being right under the 3PH control. You can see the wires a little bit through the hole, but that is OK.
Here is a shot of the lights on the top of the ROPS after the upgrade. I had a chance to try them out last night - SUCCESS!!!! /forums/images/graemlins/laugh.gif
Here is a 3/4 few of the lights from the front.
Here is a rear picture of the lights. I went with the same attachment method of using 2" X 3" square u-bolts. That had actually worked pretty well. The one thing I like about the way they are mounted now is if a tree limb does catch them it should tear them off. Should just push them back to the ROPS. I did catch a couple of limbs yesterday while I was mowing and they seemed to "hold their own." /forums/images/graemlins/smile.gif
While was in there messing around, I added another little goody too. Wonder what this button does? /forums/images/graemlins/confused.gif
Here is the wiring coming up to my surprise. All of the wiring including for the relay for the lights is enclosed in the black wiring loom as best as possible, even clear up to the starter. BTW, everything is fused within a couple inches of their source.
OK, worse then a TV show and the cliff hangers. /forums/images/graemlins/smile.gif Here is finally my surprise. You can see how I ran the wire across the top of the hydrostat cooler. But there is my surprise on the left of the picture. I added a horn!!!! Makes it nice trying to get someones attention because with the tractor running and the MMM going it is impossible to get someones attention to move something out of your way. Also makes it nice to give someone on the road a friendly toot-toot as they wave when they go buy.
I bought the momentary switch from Radio Shack (2 of them for $3.29). Had the relay laying around the house, and bummed the horn from a buddy of mine that runs a junk yard. Total Cost $1.50 and about an hours time running the wires. Oh and a little bit of fear drilling a 1/2" hole in the dash of my tractor. /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif
   / Lights on NH TC24D #19
Great posting. I just bought some 55W lights ($7 @ Harbour Freight) for my tractor (Mahindra 2615) and am planning on doing the same thing. With a FEL on there is no light hitting where I need it.
I'm trying to figure out a way to mount the lights so I can swivel one 180 degrees and get some rear light when needed. I might just mount one front and one back but thought it would be nice to be able to swivel them as needed.
Anyone done a swivel mount for auxiliary ROPS lights? I'd like to see how you did it.
   / Lights on NH TC24D #20
Jim, nice looking job. I mounted lights to my ROPS last summer and am also unhappy with the results. In my case I used yellow fog lights because I was worried about bugs swarming my head in the summer evenings, but what I found was that the yellow lights, while they provided a nice spread pattern did not provide great visual contrast in the grass while mowing. So I am planning on swapping out my yellow front facing lights for some white ones. I also have yellow rear facing lights on the ROPS as well as a white rear facing AUX light, those will all remain. But the front facing lights have to go as the yellow light doesn't show enough detail for mowing, and that is what I mounted them for.
I also thought about putting my switches where you put yours, but I have 3 switches mounted, and figured I might want more someday so I used the left fender, I figure I can actually fit 5 switches in there if I want?!? I don't know what I'd want them for, but just in case /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Anyway, your post has now inspired me to get off my rear end and swap out my front facing lights for some white ones!
Nice job on the install. And I think you might need to work out some sort of horn "code" to let the little wifey know when you need her to run out with a fresh cold beer!
New/Unused Self Dumping Hopper (A57454)
New/Unused Self...
2010 CHEVY SILVERADO 3500 HD PICK UP TRUCK (A59575)
2010 CHEVY...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Pig Statue (A57149)
Pig Statue (A57149)
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
